Old 07-26-2005, 01:26 PM
k92 k92 is offline
Default steering box rebuild
Does anyone know of where I can get a seal kit for my manual steering box for my 1970 ls6?
Old 07-26-2005, 03:01 PM
Casey Marks Casey Marks is offline
Default Re: steering box rebuild
I rebuild Mopar and GM manual boxes. If you are interested in a complete box, restored, I can set you up. If you simply want the seals, I can get you those as well. $25 for the seals.
Old 07-26-2005, 08:45 PM
k92 k92 is offline
Thanks,I just need the seals.Send me your info and I'll send you a money order. Again it's for a 1970 chevelle manual box. Rob
Old 07-27-2005, 11:48 AM
indyjps indyjps is offline
big block with manual. i can set you up with some forearm workouts to keep you in shape over the winter.
69 camaro
Old 07-28-2005, 05:43 PM
Alan X77 Hugger Alan X77 Hugger is offline
Casey,
What do you charge for re-building manual steering boxes? I am haveing some leakage from mine and may be interested in getting this done soon.
Alan
Old 07-28-2005, 05:48 PM
DarrenX33's Avatar
Ditto! Package deal??
1969 Z28
1972 Corvette
Old 07-29-2005, 05:11 AM
$250 rebuilding yours or $300 without a core (I supply the box). They are completely rebuilt and powdercoated cast iron with new seals and replated fasteners and spanner nut. If you have a rag joint that goes with the box, I can get that re-plated as well for an additional $25.
Old 07-29-2005, 04:14 PM
drdave69 drdave69 is offline
That package deal sounds good. Mine is also leaking.
Dave
1987 Grand National
Old 07-29-2005, 07:44 PM
I tell you what, if you guys can drum up (5) boxes, I will do them for $225 each. When you consider that junk boxes are fetching $100 on 'daBay, I think it's a pretty good deal. And if you want your rag joint plated -- $20 ea. (assuming we get together 5 boxes).
I'll leave it up to y'all to come up with the boxes, and we can take it from there.
PS - This is also assuming that the boxes that get sent to me don't look like they've been in the bottom of the ocean for 30 years........
Old 07-29-2005, 08:05 PM
DarrenX33's Avatar
Come on 2 more to go!
1969 Z28
1972 Corvette
