Old 09-15-2005, 04:08 PM
mrtimstik mrtimstik is offline
Default Line lock questions
Where do you all have your brake line lock activation button located??? Shifter, Loose under seat, Heck where ever? Please give me a clue where is the most common place to have it be the handiest for a casual racer. And please some tips on exactly how to use it at the track. Thanks alot guys.
1966 SS Chevy II mean and nasty
Old 09-19-2005, 09:40 PM
kwhizz kwhizz is offline
Default Re: Line lock questions
Tim.....The most common place is on the shifter....it is mainly used to lock the front brakes so you can hold the car in the waterbox and get the rear wheels spinning to heat them up........
Ken
Old 09-19-2005, 10:21 PM
Chevy454 Chevy454 is offline
Exactly how *unvisible* would you like it to be?
Old 09-21-2005, 04:50 AM
To use a line lock you push the brake pedal down as hard as you can then you press the line lock button and then release the brake pedal. (the button activates a solenoid that does not allow the fluid to return to the master cylinder from the front brakes) Now your front brakes are applied and the rear brakes are free to spin. Keep holding the button and then apply the gas and get the back tires spinning and when they have heated up let off the line lock button and come out of the water box.
Old 09-21-2005, 05:16 AM
LVCamaro LVCamaro is offline
You're bad, Rob! LOL
Old 09-21-2005, 05:23 AM
Shhhhhhhhhhhhhhhh....
Old 09-21-2005, 05:28 AM
still on the heater fan switch, huh?
Old 09-21-2005, 05:37 AM
That's the easy part to hide...
Old 09-21-2005, 07:04 AM
Exactly ... A cruise control turn signal lever from the mid 70's with the button in the end...
Old 09-21-2005, 07:55 PM
moparts moparts is offline
Could be called a line lock out, right Rob!
20 foot 75 hp good time at the lake
