Old 10-11-2005, 04:26 AM
CUL8R CUL8R is offline
Default 69 Yenko Specifications.. figures needed
Hey guys,
Im new to this forum , so pls excuse me if this is in the wrong place...
Im from the RACER ,a free Simulation which uses real life data as the physics/handling of each 'chosen' car...
We currently have a fully 3d 1969 Yenko Camaro (L72 code), which is done in all aspects except the handling, which is why Im posting here...
I already have the Gearbox ratios, Engine Torque, and diff ratio.. but thats where my luck ran out when it came to finding info..
So what Id like if at all possible is any of the following:
Spring rates
Shock rebound and bound rates
Turns to Lock
Wheel lock (not overly important but still)
Brake data
Torque/Power/Dyno Curve photo
Idle Rpm
Clutch clamping pressure
Antiroll Bar/Sway Bar/Stabilizer Shaft rates
Center of Gravity
Wheel weight
Vehicle weight
Camber (if any) on the front wheels
Toe (if any)
Also If you have any sounds they would be much appreciated as well, preferably at a constant rpm ( so samples can but cut from , to be used ingame) , starter etc etc.
Anything would be much appreciated, and the forum/website here would get a Mention in the Credits of the car when released..
Here is a few pics of Camaro's that have been released,
I worked on the '68, and the '84
The '69 is done by the same maker as the Yenko that Im currently helping out on.
Lemans blue '69
Frost Green '69
'84 Z28
'72 Camaro
'68 Camaro
Those are just a very small amount of the cars Available for racer, most are released at RSC
Cheers,Chris
Ps any questions you have feel free to ask
|RCME WEBSITE|
Don't Play With Fire, Play With V8 Muscle
Attachments - The Supercar Registry 167420-lemansblackblue6vu2a.jpg 167398-lemansblue6vu2ab.jpg
