Old 01-14-2006, 09:01 PM
joey joey is offline
Default jl8 d80 camaro found need help pricing
I have found a 69 jl8-d80 camaro with a good body origional trany and rear end motor replaced with a 400 houndstooth interiour vin is 124379n68xxxx
cowl tag has jl8-d80 in the middle with x77-d80 at the bottom how much should i pay for this car to be able to restore it and recieve a fair proffit
Old 01-14-2006, 09:06 PM
DarrenX33's Avatar
Default Re: jl8 d80 camaro found need help pricing
Please post a picture of this tag!
1969 Z28
1972 Corvette
Old 01-14-2006, 09:13 PM
Hate to throw a wet blanket on this deal, but it can't be a JL8 car with that high of a VIN. JL8 was discontiuned late May or early June. My vin is 671122 and is an 08A car (first week of August), meaning your 68xxxx car is even later.
Lynn
Old 01-14-2006, 09:17 PM
Enoch Enoch is offline
Banned
What is the build date on the cowl J-L8 cars were only made for a few months. Does it have the original rear with the disc brakes? Are the original dual piston front calipers still there? It will not have the valve on the sub frame on the drivers side. So it will have a 1 piece brake line from front to rear. And under the Master Cylinder it will only have the distribution block no extra round valve. If you could please post pictures of the cowl tag as I have never seen on with J-L8 stamped on it.
If you don't want to spend what they are asking for it I would be very interested in it and would pay a finders fee.
As far as value...done J-L8's who knows now and after Barrett Jackson it will change anyhow.
If you have any other questions about the car feel free to ask as I am restoring 2 right now and may be able to help you decide if it's real. Good luck.
Rich.
Old 01-14-2006, 11:29 PM
the cowl tag is build date oc9
cowl tag reads
st 6912437nor115671bdy
tr 718 52e pnt
jl8-d80
build oc9 x77d80
Jeff H Jeff H is offline
Like Lynn said, that VIN is too late in the year to be a real JL8 car. Double check the VIN just to make sure. But post a picture of the trim tag showing the "JL8". And if you can get a picture of the stamping on the rear post that as well. What is the rear end stamping? It could be a service package rear which is still pretty cool.
Old 01-14-2006, 11:42 PM
With JL8-d80 on the trim tag I would expect it to be a repo trim tag. There have been stranger things though. Try to get us a pic of thet trim tag.
Old 01-15-2006, 12:12 AM
JChlupsa JChlupsa is offline
Would like to see the rear end stamp as well since I have a couple JL8 rears recorded as being sold away from their cars
Like the other have said as well, get the VIN and a pic of the Cowl Tag
Old 01-15-2006, 12:30 AM
here is pic of tag my mistake no jl8 just dl80 on it
Old 01-15-2006, 12:55 AM
Wacky174 Wacky174 is offline
I see no JL8 on that tag. Hmmmmmmm
Damn LASIK must be acting up.
Wacky
