Old 02-01-2006, 01:59 AM
68TopStock 68TopStock is offline
Default 12 Bolt rearend identity
Does anyone know what GM application this 12 bolt cast number is for?
3969341NF
Old 02-01-2006, 02:44 AM
Rainer Rainer is offline
Default Re: 12 Bolt rearend identity
I'm showing 70-71 Nova and 70 Camaro 12-bolt.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 02-01-2006, 04:50 AM
SS454 SS454 is offline
70 Nova and 70 Camaro are not the same from end to end. As far as I remeber
Rick
69 RS Camaro NOT Working on it for now!!
Old 02-01-2006, 04:54 AM
They share the same center section, which is what the casting number is from. You'll have to look for other cues as to what the entire unit originally came out of. Look for a series of stamped numbers on the pass side axle tube, facing forward. There's a 2 or 3 digit letter code that will designate the original application and gear ratio.
Old 02-01-2006, 06:08 AM
Some late 69 Camaros got this center section as well.
Lynn
Old 02-01-2006, 08:44 AM
Thanks for the information fellows. I am told it was in a 71 Nova, just not sure it was original to that car. Are the external dimensions the same as for the 67-69 12 bolts for Camaro's and Nova's, if in fact it was in a Nova? The letters for the application are not readable on the tube.
Old 02-01-2006, 05:09 PM
YENKO DEUCE REGISTRY's Avatar
The '70 Camaro rear was wider than the '69 version by about an inch and a half I believe. However, the '70-'72 Nova rears were still the same as the '69 Camaro, I don't know the measurements off hand. The code usually is sufficient, but if it's not legible - gotta get the tape measure out
Marlin
Old 02-01-2006, 06:35 PM
The spring perches are in different locations on a 70+ camaro vrs a 70 nova. I seem to remember that 12 bolts in 71 camaros were early, then they went to the 8.5 corporate 10 bolt. I don't remember 12 bolts in 71 novas, but I expect they used any they had left over.
Old 02-01-2006, 06:38 PM
Chevy454 Chevy454 is offline
While on the subject, will the 10bolts they put in the later Novas sill bolt up to the 69 Camaros/Novas?
Old 02-01-2006, 06:43 PM
JRSully JRSully is offline
my original 71 Nova SS 4 spd had a 12 bolt, fun car, paid $400 for it use to eat IROC's and early 5.0 mustangs for breakfast. Those were the days
71 Porsche 911 Targa
