Old 03-17-2006, 05:48 PM
TDW TDW is offline
Default Leaf spring traction bars
I read a post a while back about clamping a piece of flat stock to the front of the leaf. Anyone use this on thier car? I need to come up with something for wheel hop. So far, the Comp Engineering ones look the best. Any better ideas? Multi leafs on it.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 03-17-2006, 06:04 PM
Chevy454 Chevy454 is offline
Default Re: Leaf spring traction bars
Before going to full blown traction bars I'd give leaf spring clamps a try...unless you're running stickies on the back, the clamps should be just fine...1 clamp per side may get it, but don't be surprised if you end up clamping every leaf on both sides...Mr. Gasket makes 'em, but they're a tad too wide and may rub the frame rail or fender, but they're easy to make, and can be anything from a 2 small flat pieces of steel & couple of bolts or a piece of round stock bent into a "U" with a piece of flat stock on the bottom with a couple of nuts...I've ran both, and they seem to be "ok"...
Old 03-17-2006, 06:53 PM
YENKO DEUCE REGISTRY's Avatar
Definitely use the leaf clamps first, start with one on each side in front of the wheels. Add as necessary. If you buy the Mr.Gasket set, make sure you have a grinding wheel to shorten them - they indeed hit the frame rail upon launch. Also, the Mr.Gasket set has bolts with too long of a shoulder, and therefore you will need to purchase shorter bolts or at least bolts without a shoulder. With this much work it may be better to follow Rob's advice and make a set.
They definitely work, I raised my launch RPM from a 1000rpm idle launch to approx. 2000prm launch with no wheel hop and minimal tire spin.
Marlin
Old 03-17-2006, 07:04 PM
sYc sYc is offline
During the SS&DI magazine test back in 1969, Ed Hedrick used 3 clamps per side on the Yenko Camaro demo car. Car got into the 11's.
BTW, Ed is an engineer, who helped Grumpy with much of his chassis/driveline problems. At the SCR Ed spoke about the time Grump watched as Ed launched Grump's car several times "inside" the shop.
Tom Clary
Old 03-17-2006, 10:33 PM
TDW TDW is offline
Thanks. I will make some clamps this weekend. They look almost too easy to make.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 03-17-2006, 10:52 PM
scuncio scuncio is online now
Tony, I can send you a pic of the clamps on my car if you're interested.
Old 03-17-2006, 10:54 PM
TDW TDW is offline
Please do Tony..Thanks
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 03-17-2006, 11:14 PM
JChlupsa JChlupsa is offline
I would like to see what they look like as well, Tony if you dont mind can you send my pics as well
Old 03-18-2006, 12:08 AM
TDW TDW is offline
http://www.lakewood-industries.com/Produ...;minselection=2
Jeff..Here are some I found. Like I say, they look pretty simple.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 03-18-2006, 10:13 PM
TDW TDW is offline
I made a set from 1/2" x 1 1/4" x 4". They work pretty darn good. I can come out of the whole hard with hardly any wheel hop now. Did a 2nd gear burnout too. Gotta watch out for Johnny Law, so I only hit it a couple of times. I won't be buying the traction bars now. Thanks all for the input.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
