Old 04-16-2006, 05:41 AM
JTH74 JTH74 is offline
Default 70-71 Hemi Cuda
What code will a 70-71 Hemi Cuda have on the fender tag to denote the Hemi engine option, and what other things would you need to look for to spot a Hemi Cuda, thanks.
Old 04-16-2006, 07:44 AM
Default Re: 70-71 Hemi Cuda
Hemi engine option code is "E74" for both years found on the fender tag. Many Hemi 'cudas also had a second tag with "HEMI FENDER" stamped into it to remind the line workers to grab the right fenders to accomodate the larger F60X15 tires/wheels standard on Hemi 'cudas. VIN also denotes Hemi motor in its code i.e. a '70 Hemi 'cuda coupe= BS23 ROB XXXXXX, where the "R" code is indicative of the Hemi. A partial VIN should be found on the radiator support, usually facing the engine, and on the cowl. Hemi motors were also mandatorily mated to the 26" HD radiator, but other BB could order that option too.
Old 04-17-2006, 02:58 AM
Thanks, their is a Cuda here in the Southeast that will probbably turn out to be nothing, but its going to be worth a look, its a 71 with billboards, you will need logging equipment to get it out!
Old 04-21-2006, 06:39 AM
thesupernova86 thesupernova86 is offline
JTH74 Keep us informed whichever way it turns out!
Old 04-21-2006, 08:17 PM
I am going to look at this car, it may be nothing, but it could be something, its back in the middle of nowhere in the South East. I have researched and know what to look for, so I will keep you informed.
