Old 05-24-2006, 09:13 PM
VintageMusclecar's Avatar
Default Opinions needed re: carb restorations, please read
I've been kicking around an idea lately and figured I'd throw it out here to guage any potential interest.
Some restorers have ALL of the steel hardware on a carb zinc plated and chromated. On certain components, this isn't technically "correct" from an aesthetic standpoint. Some examples would be certain fuel inlet fittings, throttle blades, accellerator pump levers, etc., and the biggest issue (IMO) being throttle shafts and choke shafts.
I already return what I can back to its original finish, but the one thing I can't do is dis-assemble throttle and choke shafts to try to re-plate the respective components in their individual finish(es); hence they necessitate a total zinc plate job.
It looks nice, but it's not technically "correct."
However, there is an alternative on certain carbs, as brand new throttle and choke shafts are currently available for them. I'm not going to try to post an exhaustive list, but some examples are the 4492/4555/4557 carbs, 4053/4346 carbs, 3910/3911 carbs, 3246/3247 carbs, 3810/3811 carbs, the `71-`72 GM 780 carbs, certain Ford carbs, etc.
While there MAY be some minor aesthetic differences on these new components in comparison to the originals, IMO they're much more "original appearing" than the fully zinc plated shafts are.
There would obviously be an additional expense involved (which would have to be quoted on an individual basis depending on the carb model), IMO this would be a worthwhile consideration on "higher-end" restorations.
So technically I could consider offering 2 "levels" of restorations on certain carbs; a "driver" and a "show" restoration, the difference being said new components in lieu of their replated counterparts.
Viable option or a waste of time & $...What say you?
Eric
