SEE WEB LINK
http://home.comcast.net/~musclemachi...72CHEVELLE.htm Here is an example of a nicely preserved SS Big Block car. This car is equipped with a completely Numbers Matching 402 motor, 4-speed trans., rear end, etc. IT’S NOT A 454. It just has the fender markings and air cleaner sticker. IT’S A REAL U CODE VIN SS CAR. It retains all of it original sheet metal, including floors, trunk, fenders, and rear quarters (numbers are factory stamped on the quarters). The undercarriage is very clean and rust free. Vitals: 402 BB Engine – Numbers Matching Muncie 4-speed Trans– Numbers Matching 12 Bolt 3.31 Posi Rear end - Numbers Matching Cowl Induction Hood with working flap Factory Black Buckets Seats – No rips or tears Real Code 75 Cranberry Red paint Original Rear Quarters – Numbers are stamped in by trunk area Points type Ignition Factory Rally Gauges F41 Suspension Build Sheet The car comes with a clear title and a folder full of receipts, including engine rebuild and miscellaneous parts. Engine has approximately 1800 miles since rebuild (have receipt). I also have the factory smog pump equipment with the engine manifolds, orange painted valve covers, and original water pump. Also, I have the original black air cleaner cover. What is Needs: The paint is dated. It is certainly presentable, but not show quality. It was painted approximately 10 years ago and showing its age. It has some chips and other imperfections. The front grill has a small crack. Needs a rubber Trunk seal Needs a door rubber seal by window area Cowl Induction air cleaner seal Please, if you’re interested in a Barrett Jackson restored car in perfect condition this is not the car for you. If you want to own a Genuine 1972 numbers matching Big Block 4-speed Cranberry Red SS Chevelle, then by all means call and come see the car. This car runs, drives, shifts, and performs SUPER. It is very original and factory stock. More details and pictures are available. Please call. (978) 697-8484 Asking $31,900 ![]() ![]() ![]() ![]()
"Chrome Won't Get You Home" |
