Old 08-18-2006, 07:41 AM
KnoxvillePig KnoxvillePig is offline
Default R59 Delco battery topper???
Could someone provide the link where I can purchase the piece that is placed on the top of new batteries and it makes them appear as the original R59 Delco Batteries?
Also, does anyone have any feedback or opinions on these?
Thanks
Darrell
Old 08-18-2006, 07:44 AM
camarojoe's Avatar
Default Re: R59 Delco battery topper???
Toppers Website
As for opinions... mine is that its a cool idea, and fools people that don't know any better, plus it makes a new battery look a little less ugly in a 60's era engine bay.
Joe Barr
Old 08-18-2006, 08:11 AM
Thanks for your help Joe.
Darrell
Old 08-18-2006, 08:37 AM
RamAirDave RamAirDave is offline
I agree with Joe. The original style R59s arent great, and it will at least give a correct "look" to the engine compartment.
TheMuscleCarGuys.com
Old 08-18-2006, 08:44 AM
Bavss70 Bavss70 is offline
Darrell,
After you receive the plastic top you will have to spend quite a bit of time finding a good battery to fit underneath. Most batteries are built up too much around the base of the terminals so that the plastic top won't fit down properly. After a bit of a search, I found one that fit well and had clean plain sides to match the original look.
John.
Old 08-18-2006, 06:36 PM
Ngtflyr Ngtflyr is offline
John,
Can you enlighten the rest of us as far as the brand and model?
thanks,
Dave
Old 08-18-2006, 07:33 PM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
You need one with a flat top.
Delco makes one - or some of the discount auto stores have them too.
I got mine at Sams.
Used to only buy the repros, but they just don't last at all. Go with a topper. Not as disapointing when it fails, just go get another for $49 and switch them.
Old 08-18-2006, 08:12 PM
Unreal Unreal is offline
Why doesn't someone make a "Bottomer" with the correct herringbone sides so that a battery would look correct from the sides, too? Or maybe 4 sided so it would slide over the battery much like the modern battery insulation does.
Old 08-18-2006, 08:19 PM
camarojoe's Avatar
Probably because of cost... if the top is 50.00, you can figure the "case" would be at least another 50.00 or more, added to the cost of the battery to put inside it, you'd be in the territory of a complete repro battery. Keep in mind they do make sealed R-59 repro's now, so you can get the full "look" without caps and vent holes.
Joe Barr
Old 08-18-2006, 08:39 PM
ORIGLS6 ORIGLS6 is offline
"Why doesn't someone make a "Bottomer"
We think alike. At present there isn't a "Topper" for the side post R-79s, although I did approach Carl about them.
I wondered about cutting my repro apart when it finally fails and trying to stuff a smaller battery inside it. Probably not worth the effort though so we'll continue to 'brainstorm' the issue.
BTW, I can recommend the Topper. One thing I would do though; have the Topper in hand before you buy the battery to go under it. That way you can be certain the battery fits under the Topper, not too small; not too big. Just a thought.
