Old 11-02-2006, 01:13 AM
dwwchevellen dwwchevellen is offline
Default ls6 heads
A freind of mine has a set of big block heads,cast numbers 3964291. are these ls6 454 heads? If so what application,he believes the valves are 2.25 and 1.88, closed chamber. if so what is the chamber cc and intake runner cc?
Old 11-02-2006, 02:09 AM
jfkheat jfkheat is offline
Default Re: ls6 heads
3964291 1969-70 396/402 375 L-78, Intake Port 325cc
427 425, 435 L-71/L-72
454 450 LS-6,
Closed 108.0cc
I beleive the valves should be 2.19 and 1.88. Chevy didn't use 2.25 valves in any heads.
James
1968 Beaumont SD396
Old 11-02-2006, 02:37 AM
Good deal James ,I think Im going to try and talk him out of these heads and use them on my gen v 454 Im putting in my 70 chevelle SS( reproduction ls6454 4 spd ) car. Thanks a lot for the great info.
David.
Old 11-02-2006, 02:46 AM
Chevy454 Chevy454 is offline
Can you put Gen IV heads on a Gen 5? I thought there were coolant passage changes on the Gen V's? Also, no fuel pump boss on a Gen V...
Old 11-02-2006, 03:17 AM
WILMASBOYL78's Avatar
I think you can use a diff head gasket set up on one of those combos and make it work ....have to check one of GMPP dealer's sites to be sure.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-02-2006, 04:39 AM
Yea, please check on that I'd hate to make a deal with him and not be able to use them,Im running an edelbrock two four set up on the gen v so an electric fuel pump is needed.
under the hood two fours, but if the ls6 heads will not work then i will go with edelbrok rpm heads.
