Old 01-04-2007, 05:25 PM
JHS JHS is offline
Default body panel alignment problem
Assembling my 1970 Nova and having problem with cowl panel alignment. The fenders align correctly with the doors, as does the hood, but the cowl panel does not; it sits a little lower than the top of the fenders and hood. Am I missing some sort of bracket or shims needed to elevate the cowl panel for proper alignment?
'70 L78 NOVA SS
'77 Bronco
Old 01-04-2007, 06:05 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: body panel alignment problem
There are shims that go under the small screws that hold the cowl onto the top of the f/wall. The cowl panels generally fit very poor, especially at the ends where it goes under the windshield reveal molding. There are triangular shaped, closed cell foam, wedges that are glued to the underside of the cowl - I'm not totally sure what they are for, but.....
Marlin
Old 01-04-2007, 08:57 PM
JHS JHS is offline
Thanks, the assembly manual was some help, going to a junk yard to look at a nova that still has the cowl panel and see what I can figure out.
'70 L78 NOVA SS
'77 Bronco
Old 01-05-2007, 04:51 AM
Allen Allen is offline
I believe the foam is there to prevent debris from going past that point and collecting down between the inside of the fender and the cowl side panel. Of course, when that foam falls off, then stuff gets down there and contributes to rotting the fenders from the inside out.
Allen
1970 Nova SS L34 396/350hp, 4-speed, 3.31 gears
1969 Corvette 350/300, 4-speed, 3.36 gears
Old 01-07-2007, 04:13 AM
mbxlesney mbxlesney is offline
I always believed that they were there to help the air feed into the heater core better. I know I have never seen any NOS ones of these.
Kim
1970 Nova Fathom Blue L78 M21 3:55
1970 Nova Classic White 454HO THM400 4:10
Old 01-07-2007, 04:51 AM
l78ss l78ss is offline
shims are a easy fix
but if you don't like using them the panel is made of sheet metal and can be tweeked to fit by a good bodyman
69 L78SS
Old 01-08-2007, 07:34 AM
L78steve L78steve is offline
Shims were used from the factory.
Old 01-09-2007, 04:27 PM
JHS JHS is offline
Went to the junk yard and found the donor Nova. Removed the cowl panel and was surprised to see the number of shims that were under the screws! It appeared that a bunch of shims had been glued together at the factory to create one really thick shim, does this sound correct? I put these shims under my cowl panel and it aligned pretty good. Just want to make sure that this sounds correct or did some back-yard mechanic jury-rig this Nova. Anyone got a pic of the cowl panel by the hood hinge, showing the shims?? Thanks.
'70 L78 NOVA SS
'77 Bronco
Old 01-09-2007, 04:32 PM
I can't say that I've seen 'factory glued shim packs', but the factory would/could use more than one shim at a given location. There are several different thickness' to the shims, so it's feasible that GM would mix-n-match as necessary.
Marlin
Old 01-09-2007, 05:47 PM
-----I think those thin shims tend to get glued or stuck together by rust. I have noticed this frequently......Bill S
