Old 01-30-2007, 04:29 PM
dec31 dec31 is offline
Default SW 990B tach and 970 transmitter?
I was wondering if anyone out there can tell me what exactly the function is of the 970 transmitter block for the SW 990B tach. What does this unit do. I did call SW directly and no one there could tell me, the company has changed hands so many time the info is no longer available . I would appreciate the assistance
thanks Chris
Old 01-30-2007, 05:06 PM
68l30's Avatar
68l30 68l30 is offline
Default Re: SW 990B tach and 970 transmitter?
FYI....990B is the transmitter......970 is the tach...
Steve
Old 01-30-2007, 07:37 PM
Chris,
I believe all it does is reduces the voltage to the tach. I opened one up at one point and if memory serves me correctly the only thing inside is a resistor on the 12V area.
Jason
Old 01-30-2007, 08:10 PM
Steve Shauger's Avatar
Administrator
I am not sure, but the transmitter probably conditions the pulses coming from the distributor, and integrates them. Basically the # of pulses for a period of time represent a voltage, more pulses the higher the corresponding voltage is. The meter movement is a voltmeter calibrated to convert voltage to a corresponding RPM's.
www.yenko.net
www.vintagecertification.com
Old 02-02-2007, 03:14 PM
Thanks for the input guys. May have to make a trip to a electronics shop and have them test it to figure out what it really does for sure.
Thanks again for your help
Chris
