Old 02-11-2007, 10:46 PM
Default 1972 Nova Trunk Paint
Hey Guys,
I am in the process of restoring the trunk on my 72 SS Nova. I wire wheeled it, primed and sealed it. Now I am at the step of spraying a spatter paint on it and then clear coat. Ground up sells two different spatter paints. Which one is closest to the Factory Finish? Or if you have had success with a different spatter paint. What paint is it and does it come close to the Factory Finish?
Thanks in advance,
-Dave
Old 02-11-2007, 10:52 PM
Default Re: 1972 Nova Trunk Paint
I am not sure any are real good in a rattle can. I would talk to Frank Arone or Brian Henderson before I do anything. JMO Sam
Old 02-11-2007, 11:04 PM
Hi Sam. Thanks for the quick reply. I know that Brian has the original formula or something very close to it for the factory spatter paint. But, I think for this car I am going to go the rattle can route.
Thanks,
-Dave
Old 02-11-2007, 11:06 PM
WILMASBOYL78's Avatar
Dave, you could also check with the folks at NNN...I'm sure they can offer good advice for the do-it-yourselfer....
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 02-11-2007, 11:10 PM
Hey Tom... That's a great idea.
Thanks
Old 02-11-2007, 11:44 PM
mnyenko mnyenko is offline
Eastwood black-aqua splatter paint in the can works for a driver. Cover the trunk floor. Half way up the quarters. Do not spray the marker lights. I would not clear over the splatter. Gives it a yellow cast. It is easy to touch up again and again. Earl
Old 02-12-2007, 03:09 AM
3macs1 3macs1 is offline
Is the GM rattle can splatter paint acceptable for a show car??
Old 02-12-2007, 05:12 AM
jtower1969 jtower1969 is offline
I used the Eastwood kit..but you have to use the clear over the color. My car is a driver not a showcar.
Old 02-12-2007, 06:15 AM
1968 nova ss 1968 nova ss is offline
sam,I sprayed my 68 nova ss 396 with this method ;it looks like factory.I sprayed a few coats of ppg dp90(kind of a semi-black)on the second coat ;while it is still wet, fog in with the splatter color rattle can.It will dry up to a nice even sheen.Chris Teed
Old 02-12-2007, 06:19 AM
Oh : I mean Dave;try this method above it will look awesome.chris Teed
