Old 02-13-2007, 05:48 AM
Chevy454 Chevy454 is offline
Default pulley part #s
wp 3995631ao 11
crank 3751232bb
Anyone got any idea what these are for? They're for a small block I believe, if that helps...
Old 02-13-2007, 05:58 AM
Default Re: pulley part #s
I believe WaterPump pulley #3995631 AO is for 1971-75 Small Blocks w/61 Amp Alt,..not possible on a Solid lifter SB,and 1973-74 ALL w/454 CID.
Crank Pulley #3751232 BB is for nearly Every Small Block 1965-68 Corvettes(w/AC)-Trucks-Passenger w/Hydra lifter 283 & 327 & 350 CID w/P/S,and 1964-68 Chevelle-Chevy II-Camaro w/Hydra lifter 283 & 327 & 350 CID w/P/S but w/o AC...and 1975-77 Monza 262 w/o AC.
Old 02-13-2007, 02:33 PM
Rixls6 Rixls6 is offline
My 70 Chevelle assembly manual shows #3995631 AO as being correct for the L34 and LS5 Chevelle also.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 02-13-2007, 08:44 PM
You're right Rick,there is a revision noted for those vehicles built w/AC after 6/3/70,which coincides around the time this pulley was first produced.
It looks like this pulley was as a replacement part on late 1969 Big Block & Small Block Hydra lifter vehicles WITH A/C as well as original equipment from LATE production 1970 through 1976 vehicles with same.
