Old 02-28-2007, 04:27 PM
m22mike's Avatar
m22mike m22mike is offline
Default 69 Nova dash paint
I am doing some work on a 69 Nova,and have noticed that the upper black dash paint forward of the dash pad has a suede like texture to it. Unlike the lower dash that is smooth semi black.
Any ideas on how to reproduce this finish ?
Old 02-28-2007, 04:40 PM
micky69396 micky69396 is offline
Default Re: 69 Nova dash paint
Mike, Unless you can find a suede additive your going to have to be creative on how you do it. Im on my last little bit of mine here and I have been looking for a while now with mixed results on some other products. Most have too much texture to them now. You can use multi coats of sprying it dry to acheive the look. If you can get some lacquer it works better than the enamels.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 02-28-2007, 05:29 PM
Ralph Lauren has a suede texture paint at Home Depot... I do not know if it is an additive or if it is a base to which color is added... just a thought...
Old 02-28-2007, 05:40 PM
ORIGLS6 ORIGLS6 is offline
Not sure how well the 'Ralph Lauren' stuff would hold up to UV exposure through the windshield.
Sherwin-Williams used to offer a flattening agent you could add to enamel. It gave a truly flat and textured appearance to the final job, but I don't know if it would work with lacquer. I agree, you need to spray it 'dry' to get the texture you're after.
Old 02-28-2007, 06:46 PM
GeorgeLyons GeorgeLyons is offline
Lacquer reduced with a fast thinner and applied at normal air pressure, medium coverage (not wet) coats gives a near perfect to original top of dash finish. After last coat if it is still too smooth/shiny, a quick even dry coat at slightly higher pressure will give you more flat/dry look. By now you have color coverage so it is easy to play around and get it dead on. I just did my '71 Blazer 2 weeks ago like this and results are dead-on. PPG Lacquer, I can get it if you need a source.
Old 03-01-2007, 02:33 AM
L30M20 L30M20 is offline
Mike, its the same on camaros, let the "dry" overspray from priming lay down on it,either top coat with Lacquer, or with Rust-Oleum Texture spray, or use RM black with suede additive.
Old 11-21-2007, 06:37 PM
Nova Jed Nova Jed is offline
I just had a pint of lacquer made up with the texture put into it. I will let you know how it turns out.
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 11-21-2007, 06:43 PM
Shoot a small test area first. Laquer will lift old paint in a heartbeat. Best bet is to shoot over a well prepped surface that won't react to laquer topcoats.
Old 11-23-2007, 05:15 AM
Bob Hollinshead Bob Hollinshead is offline
I never seen any dash tops with texture like you're describing. Are you sure this thing wasn't repainted some time back? It should be low gloss like eggshell but smooth with no more texture than the lower part of the dash. A singlestage urethane is your best best for durability.
Old 11-23-2007, 06:23 AM
m22mike's Avatar
Have to dissagree here. The dash tops were differant from the factory. There was infact a suede addative that went into the lacquer paint. It was not rough to the touch, but had a texture to it much like suede.
here is the other thread on the subject. The issue's here is not what the finish was, but who can still mix it in lacquer.
https://www.yenko.net/ubbthreads/show...ge/0#Post14569
Thanks Mike
