Old 03-11-2007, 01:14 AM
WILMASBOYL78's Avatar
Default 272 block...
Looking for info on how much a stock 1969 396/350hp 272 2 bolt block can be bored....I plan on sonic testing before doing any work...just wanted to get any feedback from those who have done it before....
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-15-2007, 07:27 AM
Default Re: 272 block...
Been doing some research on a stroker kit for the 396...Speed-o-Motive offers a pkg to put 454 crank in 396 block to get 434cid...with .30 over you get a 440 BB..power figures from different articles seem impressive...any thoughts..??
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 03-15-2007, 09:16 AM
.030 over seems standard. I would expect at least .060.
Jason
Old 03-15-2007, 11:10 AM
JoeG JoeG is offline
You're right--The 396 is a meaty block.......060 over is no problem...
Do you have to notch the bottom of any of the cylinders for rod clearance because of the longer stroke....
Old 03-15-2007, 05:01 PM
Most of the stuff I have read says clearance work is needed for the rod bolts...crank is not an issue...a lot of guys recommend limiting the overbore to .30 to minimize any potential cooling issues....this stroker idea is pretty cool...any other thoughts are welcome...
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 03-16-2007, 08:10 PM
Tom,
A few members over on the NCRS site told me that the main
reason for the large influx of '6223 crankshafts over the
past 2 years is because of the stroker cranks for the 396
and 427 engines. All that additional power with the same
bore must be appealing to the non-original crowd.
I'm interested in your findings - please keep us informed.
Steve
Old 03-16-2007, 10:07 PM
Apparently, with no core shift, people have gotten away with .125" over. Machining heads for hardened seats sometimes hits water according to my machinist, and others. Not good. If you are using older heads, they probably have enough carbon soak that the seats will be ok anyway with unleaded gas. The extra stroke sounds interesting.
