Old 03-11-2007, 08:27 PM
Meresq Meresq is offline
Default Rear axle tube stamping
I re-checked the stamping on the passenger side tube of the rear axle on my 1969 Chevelle hoping to find "KQ". I had originally found the stamping 0821K. Unfortunately, on rechecking the number (using a scotch brite and a little brake fluid) the stamping is 0821K--there is not another letter after the K. Anyone have any idea how this could be? Could it possibly be a factory replacement rearend? The passenger side tube has the VIN stamped on it and it looks like the driver side tube may also have the VIN stamped on it. Any ideas?
Thanks.
Mike
Old 03-11-2007, 09:15 PM
Default Re: Rear axle tube stamping
Is there an E on the tube anywhere? to the left or under the stamping?
Old 03-11-2007, 09:39 PM
Rainer Rainer is offline
Thanks.
Mike
Engines and transmissions are the only drivetrain components that are VIN-stamped to match the car.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 03-11-2007, 09:50 PM
That looks like it would decipher as August 21st.
The K would stand for the plant code which is McKinnon.
Look for a two letter prefix before that assembly date you just listed,like KK or KF.
CRG Reference topic
Look for the rearend casting date at the 4 O'clock webbing position while staring straight at the bullnose cover.
I agree,I've never seen a CON VIN stamped into a rearend axle tube before.
Old 03-11-2007, 10:13 PM
ChevyThunder's Avatar
ChevyThunder ChevyThunder is offline
For reference here is an example for you of the axle in one of my cars.. The "G" in my application being the Detroit Gear plant..I have also never heard of a VIN stamp on a rear end. I would have to believe a previous owner had that done for ID purposes
