Old 03-20-2007, 08:59 PM
tirebird tirebird is offline
Default trim tag mystery
I'm trying to figure our a couple of minor mysteries on my TransAm's trim tag.
Line#1 - 71-22887 L 02607
71 Firebird TransAm built in VanNuys, body #02607
Line#2 - TR 219 11 11
Black trim, Cameo white, but why are there two paint numbers(the 11) instead of one?
Line#3 - 09c 022024 150357
Car was built the third week of September. But, the other two numbers are a mystery.
Can anyone help?
Thanks,
John
1971 BFG "Tirebird"
Old 03-20-2007, 09:37 PM
Default Re: trim tag mystery
I believe the 11 11 means upper and lower body colors, ie both the top and lower part of the car were painted the same color. The remaining two numbers were internal scheduling codes used at the LA plant which do not have any useful information that I know of. My 1970 LA built Z-28 has the same codes.
Paul
Old 03-20-2007, 10:19 PM
Rainer Rainer is offline
Right. So in the event that you had two-tone car (painted top) or a vinyl top car, the second number would designate the color for it.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 03-20-2007, 11:49 PM
Thanks guys. Yes, the car was cameo white with blue stripe, so the "11 11" makes sense.
Old 03-21-2007, 02:03 AM
njsteve njsteve is offline
Mine says the same thing. "11 11"
Old 03-22-2007, 08:44 PM
elcamino elcamino is offline
022024 150357 is the DP Sequence No. It will appear on the build sheet and was used for processing and linking together all production departments throughout the facility, part of an electronic "broadcasting" system that assures that the correct parts and accessories for a given car will arrive at the proper place at exactly the right time.
They put it on the tag so as to be able to ID the body when it arrived in the body bank in the final assembly plant. GMAD plants assembly and supplied sub-assemblies for many different GM Models.
DP - Data Processing
NEW cars I had..
66 Impala SS396
70 Chevelle SS 454
72 El Camino SS350
73 Chevelle SS350
