Old 04-29-2007, 09:40 PM
WILMASBOYL78's Avatar
Default Need a TH 400 guru...
Having trouble with kickdown on our 68 BB Nova with th400 and Gear Vendors OD....it will only downshift via gas pedal when the car is going less than 40mph...above that, nothing. Would love to discuss this situation with someone who really knows this stuff...any help would be appreciated.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 05-02-2007, 05:01 PM
L78steve L78steve is offline
Default Re: Need a TH 400 guru...
Why do you feel this is abnormal?In overdrive the governor is spinning slower so the shift points will be at a higher MPH.
Old 05-03-2007, 04:37 AM
I should have been clearer.....this condition is without the O/D engaged....
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 05-03-2007, 08:10 AM
Have you done any checking on the detent down-shift system?Check your switch for 12V supply with ign.on.Then activate switch and check for 12V output at the wire that runs to the drivers side of the trans.If you have 12V signal at the trans.you will need to check the solenoid inside pan.This can be done without removal of the pan.Disconnect the wire at the connector and check for continuity with an ohm meter.Hook one meter wire to the spade on trans connector and the other to ground (trans case).You should get a reading if solenoid is good.If it reads a zero resistance,suspect a shorted wire or solenoid.This detent should give you a full throttle down-shift up to about 70mph in 3rd gear.Or a second to first up to around 30mph.You may be able to hear a faint click at the pan when the detent switch is hand operated with ign.on if solenoid is functioning.
Old 05-03-2007, 10:45 PM
Dusk Blue Z Dusk Blue Z is offline
I talked to a good friend that has worked on GM automatics for years about your problem. He asked a couple of questions about your car.
1. What rear gear are you running?
2. Does it short shift during normal acceleration?
I'll forward your answers to him as his computer just smoked it's hard drive last night. He did think if your running a 4:88 or so the transmission might be running just like it was designed to. He thought you may have to play with the govenor springs to make it shift differently, also didn't know if there were springs you could by from the aftermarket that would work or just trial and error to get your kick down points right. He said a governor from an old school bus with a TH 400 might work as they ran a pretty steep gear.
Mike
Old 05-04-2007, 12:25 AM
Mike, thanks a lot for the help....car has a 4.10 rear..27" tire....I have a couple of hi-perf governors....got a date tomorrow morning with a local tranny guy to kind of look things over...and yes, I think it short shifts under normal circumstances....what I am looking for ideally is to duplicate function of CW/CX code trannys from back in the day....high shift point..firm response...tom
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 05-04-2007, 04:39 AM
JRSully JRSully is offline
Wilma, John Force just called, he said he has an old airshifted Lenco available that should bolt right, I would jump on it
71 Porsche 911 Targa
Old 05-04-2007, 06:01 AM
Motion Camaro Motion Camaro is offline
<font color="blue">I could use a Lenco ... </font>
Mike Fabian
Old 05-04-2007, 04:51 PM
Tom, Good luck, I can put you in touch with my friend if you don't get the results you are looking for. Sounds like your on the right track.
Mike
Old 05-05-2007, 05:04 AM
Met with a local tranny guy today and he drove the car....he feels the governor is the main problem. I have a couple of vintage hi-perf govs from L78 cars...gonna change one this weekend and then we will see...more to follow.
wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
