Old 05-01-2007, 09:17 PM
bob69z28 bob69z28 is offline
Default correct plug wire stands 69 z28 ??
can someone tell which is the correct stand for the plug wire on the drive side for a 69 Z w/cowl hood. I've seen one with a straight neck and one the bent towards the firewall. The base is the same with the two intake mouting holes.
Old 05-01-2007, 10:03 PM
47Hammer's Avatar
47Hammer 47Hammer is offline
Default Re: correct plug wire stands 69 z28 ??
It looks bent to me, if you can blow up the picture and get a better look, this might help you out.
Old 05-02-2007, 04:36 AM
thanks for the great referance picture. I've been trying to find pics like this to see the original stock look. Do you have one of the other side of the engine. The previous owner had used many 68 parts and i'm bring my 69 car back to stock as possible except for the header with i like. I am buying orginal parts were possible.
Old 05-02-2007, 07:17 AM
47Hammer's Avatar
No problem, here you go. I hope this helps.
Old 05-02-2007, 09:39 PM
thanks for the pics
