Old 05-08-2007, 11:12 PM
quick-bowtie quick-bowtie is offline
Default 1970 Camaro SS396 REAL DEAL needs finishing..
I bought this car last year with intentions of cleaning and preserving it, When I bought it it had original paint and I tried to save it but ended up painting the car. I just got it back from the paint shop and it still needs to be wet sanded and buffed.
Car has BORN WITH NUMBERS MATCHING Engine, 12 bolt rear, and I believe transmission (I will have to double check) car is was so correct and original so Ive got to believe the trans is also original but I will check.
Original Citrus Green car with Dark green interior, Interior is original with only the front drivers bucket and dash needing replacment.
Engine runs good it is currently out of the car because I was going to detail everything, I put so new gaskets etc just basic freshing. Very solid car, rear of truck pan by the tail light could use alittle minor minor work but definately doesnt need replacing.
The first few pics are when I bought the car and the rest are as it is in the current state.
Car has factory 12 bolt with sway bar, gauge package with tach, tilt wheel, console, Citrus Green, Good solid legit easy project. I can drop the motor back in if needed.
PRICE 17k FIRM. I have more than that into it. 507-208-0191
69 NASCAR PACECAR Camaro 1 of 7
68 Shelby GT500 Convert
Some other GM and Mopar
