Old 05-31-2007, 09:46 PM
Default Tranny/Rear Axle Lubricant Pump.
Looking for recommendations and sources for either a hand pump or pneumatic (shop air) system for putting oil in trannys (side fill) and Rear Axles.
Thanks!
Old 05-31-2007, 10:22 PM
Default Re: Tranny/Rear Axle Lubricant Pump.
Sam, Usually the 1 quart plastic bottles have spouts/tubes you can use. They are about a foot long that go over the small opening in the spout. The plastic flexible tube is about the correct size to stick in your trans or rear hole fill. Maybe you are looking for something more permanent? Sam
Old 05-31-2007, 10:50 PM
jtower1969 jtower1969 is offline
I purchased a pump (looks like a hand soap pump with a clear tube attached) at pep boys...It's was designed to put oil in outboard motors..but it worked just fine for filling up my M21. It was over by the "help" isle
Old 05-31-2007, 10:53 PM
Good input guys. Sam, I have used the spout tubes and longed for a better solution. It does work, but it takes a long time and is not very efficient. Guess I am looking for a more permanent solution. Jtower - will check out Pep Boys. Thanks guys.
Anyone else?
Old 06-01-2007, 06:10 PM
budnate's Avatar
budnate budnate is offline
pep boy pump, and the 1 gallon container of oil and your set, and a 3/8 holley vacumm port plug to cap the oil tube when done..
Old 07-07-2007, 01:01 AM
Fellas,
Bought my $9 pump at Pep Boys and it works teriffically. Thanks for your help!
