Old 07-07-2007, 05:20 PM
66 Biscayne 66 Biscayne is offline
Default Starter
Hello, Maybe someone here can identify a starter I found while cleaning the garage...# 1108352 dated 1 E27 8 which I believe to be 1971 may 27...came off a big block motor I had a few years back...would appreciate the help.....by the way it does have what looks to be a aluminum "nose cone"...and the mounting bolts are off set....it did work fine when removed. Thanks Much
