Old 07-17-2007, 06:16 PM
YENKO DEUCE REGISTRY's Avatar
Default Coils
How many volts is a stock 293 coil? Is there a performance advantage to step up to blaster coil? Does a blaster coil require a ballast resistor - and if so, what exactly is a ballast resistor?
Marlin
Old 07-17-2007, 06:43 PM
Default Re: Coils
Marlin, I don' tknow the specs on the 293 coil, but the "blaster" coils are internally designed to not use a ballast. IF there is a ballast in the original wiring,it needs to be jumped.
Most hi-perf factory coils came with a ballast resistor in the circuit from the switch to the Pos. terminal of the coil. When the switch is in the Start position, the ballast is by-passed by the wiring in the harness so the coil gets a full 12V on the primary. When the switch is in the Run position (or ON pos.), the feed is through the ballast and lowers the voltage across the points to about 3-4 volts which saves point life. That's the purpose of it. IF you use a coil that was designed to use a ballast and it shorts or is by-passed, it will cook the coil. I hope that explanation made sense.
Verne
Also, a lot of cars use a resistance wire rather than an external ballast resistor. In that case, there are 2 wires going to the Pos side of the coil. One is the white braided resistance wire and the colored wire supplies the full 12V for Start. In the On position, a lowered voltage is supplied to the coil through a resistance wire.
Old 07-17-2007, 07:12 PM
Default Re: Coils
I see... interesting. I believe my car has the braided wire deal. That makes sense about the coil needing the whole 12V on startup.
Anyone know if the stock coils go 'bad' over time, and deliver less voltage?
Marlin
Old 07-17-2007, 07:43 PM
Default Re: Coils
I just picked up 3 used ones at SCIndy,and then 2 more at Iola last week.
My experience has been they are pretty bullet proof.
Their achilles heel is if the oil dries up or leaks out after abusive behavior.
Old 07-17-2007, 09:55 PM
Default Re: Coils
Marlin, Check your shop manual and there should be a procedure for 2 resistance checks of the primary and secondary side. IF you can't find it, I can look up a procedure for you.
Verne
Old 07-17-2007, 10:26 PM
Default Re: Coils
Marlin, Maybe this will help you: 1115293 ignition coil (ohms @ 80 degrees F). Primary resistence= 1.77 to 2.5 ohms. Secondary Resistence is 3000 to 20,000 ohms. Ignition resistor loom is 1.35 ohms. Taken from an original Sun Electric Corp. tune-up chart.
Old 07-18-2007, 04:31 AM
Chevy454 Chevy454 is offline
Default Re: Coils
Make sure you go with an oil filled unit...don't remember on the Blaster, but Accel offers both the epoxy & oil version for the same application...oil handles the heat better and is supposed to be more durable.
Old 07-18-2007, 11:55 PM
Default Re: Coils
Marlin,
When I replaced my original Pertronix setup with the Ignitor II setup, I went with the corresponding coil (60 KV if I remember correctly). It called for the removal of the resistor wire to the coil. If you have a coil that is designed for 12 full volts, it will not lose as much voltage at the higher RPMs as the coils designed for the ballast wire/resistor. It will lose time for coil saturation as the revs go up, but the higher voltage going in will allow for less of a drop off in working voltage.
One of our friends was at Martin was having trouble with his motor breaking up and not wanting to rev beyond 4500 rpm. Two sage individuals from Canada told him to close the spark gap on the plugs. His old coil was not producing enough voltage at the higher revs + the higher compression of the motor to jump a gap. Close the gap, less voltage to arc the plug= best performance out of the car ever. 13.07 out of a 1964 Merc 427 Maurader!!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 07-19-2007, 12:08 AM
Default Re: Coils
Good info Rusty. So, if you have more voltage from the coil, does that mean the spark gap should be opened up a little?
Marlin
Old 07-19-2007, 03:08 AM
@wot @wot is offline
Default Re: Coils
Correct.
Dean
