Old 08-02-2007, 07:58 AM
427king 427king is offline
Yenko Paid Member
Default power windows 1969
can anyone tell me if this is a 69 chevelle or 69 elky regulator? thanks
Old 08-03-2007, 10:00 AM
Yenko Paid Member
Default Re: power windows 1969
ANYONE????
Old 08-03-2007, 10:28 AM
deuce-less deuce-less is offline
hey king,
is it possible that the two wdw regulators interchange?
making them useable on either model
alan
Old 08-03-2007, 10:39 AM
Yenko Paid Member
Alan, i thought they did originally but i was told twice after that they were different. Id guess 68 thru 72 chevelle are the same and 68 thru 72 elky are the same, but i dont think they interchange between the different models.i could be wrong though.
Old 08-03-2007, 05:03 PM
68l30's Avatar
68l30 68l30 is offline
The Elky ones are different than the Chevelles.....
Steve
Old 08-03-2007, 07:35 PM
Rainer Rainer is offline
If I recall correctly, at least on the manual regulators, the appearance is identical but the spring tension is different. Since the 69 window is larger it weighs more and thus requires more spring tension to raise it. The same concept probably applies for power windows, but instead of a stronger spring you have a stronger motor in a 69 unit.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 08-04-2007, 10:48 AM
Kurt S Kurt S is offline
The window motors are the same for all Chevelle models, Elky inluded.
Kurt S - CRG
Old 08-04-2007, 10:49 AM
Yenko Paid Member
What about the regulators??
Old 08-04-2007, 03:49 PM
Woj's Avatar
Woj Woj is offline
I've got a set of pw regulators that are supposed to be off a 69 Chevelle and the door regulators are different than the one in your post. The regulator that I have has an extra arm between the gear and the main arm. The main arm on the ones I have measure 22" from tip of the roller to the opposite end.
Phil Woj.
Old 08-04-2007, 08:11 PM
Yenko Paid Member
Thanks woj, thats exactly what i needed to know. The regulator i posted was with a 69 elky,and should be different than a chevelle but i wasnt sure.
