Old 08-10-2007, 01:28 AM
copo69's Avatar
copo69 copo69 is offline
Default '69 Camaro brake caliper problems and questions
I have a problem with my '69 front calipers. First I had problem with car pulling to right so I changed the brake hoses, (few miles but 12 yrs old with silicone fluid) still pulled a bit but after dragging brakes for about 1/2 mi it cleared up and was fine however had a leak between caliper and brake hose fitting. I cannot get the leak stopped. I checked caliper for cracks, none, and hose appears OK. Seating surface on caliper looks OK but didn't get good crush marks on copper washer but it was correctly torqued then slightly over torqued and still leaked. New washers ere about .003 thinner. This leak was static. I removed caliper inspected everything again and bench tested with air but still get leak. I'm ready to pull my hair out. Anyway, I'm just about ready to replace the calipers although I hate to give up these as I'm 99% sure they're original and had them resleeved with stainless by Stainless Steel Brakes 12 or so years ago. I looked at the catalogs and I see "technically correct" so I assume same caliper used for other years. Anyone know what is correct casting #'s for '69 and how many years they were used? One catalog lists cars made before and after 11/69. I can't find any info on numbers anywhere...books or on the net. Anybody know what we need to look for? Any rebuilt calipers better than others? What is the correct finish on 'em...black paint or natural? What are the restorers using? Thanks
