Old 08-12-2007, 08:18 AM
Norwood Norwood is offline
Default 1970 Camaro window blow out clips
If you are an owner of a 1970 Camaro or Firebird you know that they have many parts that are exclusive to them. This window blow out clip is one of them, it may very well have been used on some 71 cars as well. This is a Reproduction of the original clip. it is an EXACT REPRODUCTION of the 1970 clip. It is made from stainless steel and will not deteriorate like the original. The later clip is much larger an is not correct on a 70. This clip could be used as a replacement for any 1970 thru 1981 Camaro or Firebird Trans Am, although the hole centers for mounting this clip are made to fit a 1970. I have a very limited supply of these. Please ask questions before bidding. As with all my parts these are guaranteed to fit and function just like the original. 20.00 + 5.00 S/H Thanks
Old 08-12-2007, 10:03 AM
Default Re: 1970 Camaro window blow out clips
Craig, At what Email and/or address do I communicate with you regarding the clip.................
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 08-12-2007, 03:33 PM
[email protected]
Old 08-12-2007, 03:40 PM
The channel that this rivets to is also a 70 only part. It is made from polished Stainless not painted black like later years. As I stated in the previous post the hole centers on this are closer together than the later clip. You could use this on the later channel but you would have to drill one new hole
Old 08-12-2007, 04:48 PM
Here is a pic that shows an original 70 clip compared to the later style
