Old 10-04-2007, 07:45 PM
427king 427king is offline
Yenko Paid Member
Default Engine rebuilding
For a limited time only i will offer a engine rebuilding service. 1350.00 plus parts. Includes all normal machining[all when applicable]crank grind,rods recon,install cam brgs and freeze plugs,all cleaning,boring,dissasembly of your motor,valve job including guides and surfacing,press rods on and off,resurfacing block ,magnafluxing,complete long block assembly, Bad holes,repairs,cracks,line boring,balancing,pressure testing,bush rods etc if required is extra. L78 L72 ZL1 L88 Z28 and all others. Dyno testing available.
Old 10-05-2007, 06:16 AM
RPZ28 RPZ28 is offline
Default Re: Engine rebuilding
Hi Chuck, I went to look at a DZ block that is for sale the other day, but it has a crack in the deck from one of the head bolt threads to #3 cylinder. Is this something that can be repaired?
Thanks Ron
Old 10-05-2007, 06:52 AM
Yenko Paid Member
Send a pic. Can sometimes use a torque lock insert in a bad hole depends really on the crack and just how bad. Deck surface crack is normally easy
