Old 10-06-2007, 11:55 PM
Lemans69 Lemans69 is offline
Default 1969 Camaro Coupe
1969 Camaro Coupe, Black Plate California Car, Original 6-cylinder automatic car, now has a fresh 350 with a rebuilt Muncie 4 speed, power steering, manual brakes, the car is an unrestored original with 81,000 correct miles, mostly original paint, never restored, all original sheetmetal with no rust, excellent original rust free floors, original Lemans Blue with Black standard interior, has original factory white stripe, a true original survivor that runs and drives great.
The current new driveline only has about 300 cruising miles, and has the following parts:
350 Small Block
492 Angle plug iron heads
Edelbrock Performer RPM Aluminum Intake Manifold
Pertronix Ignition system in points style distributor
Comp Cams Magnum 286H cam and lifters
Roller tip rockers
Holley 750 vacuum secondary carburetor
Hooker Competition Headers
Flowmaster American Thunder 2 1/2” dual exhaust system with stainless tips
Rebuilt Muncie M21 transmission
Lakewood scattershield with block plate
11” Zoom clutch
New Hurst Competition Plus shifter
10 bolt 3.73 positraction rear end
This car also has the following parts:
American Racing Torque Thrust D wheels, 15 x 7
BF Goodrich Radial T/A tires, 215/70/R15
New GM rear spoiler
New 3/8” fuel tank pickup
New 3/8” fuel line
New windshield
New black carpet with underlayment
New headliner
New dome light
New sail panels
New package shelf
Comfort Grip steering wheel
Sun Super Tach II tachometer
New chrome gauges, oil, water, volts
New window crank handles
New pedal covers
New wheel opening moldings
New side view mirror
The body has the typical dings and scratches you would expect from an original 38 year old car. The front bucket seats need to be reupholstered, and there are two small rust holes in the center of the trunk due to the rear window leaking. This car would be an easy restoration, or continue to drive the car as is. $19,000.00. Call with questions at 847-923-7516.
Pictures will be posted later today.
