Old 11-03-2007, 02:25 AM
scott s scott s is offline
Default chevelle frame interchange question??
my buddy needs a frame for his 72 chevelle will a 70 monte carlo frame work???
Old 11-03-2007, 02:38 AM
StriperSS StriperSS is offline
Default Re: chevelle frame interchange question??
I don't believe so. If you open the hood on a Monte Carlo, you'll see the engine sits much farther back. The fan shroud almost looks like a playground tunnel.
Old 11-03-2007, 02:58 AM
Dog427435's Avatar
Dog427435 Dog427435 is offline
Hollander manual shows a 70 Monte frame will not work.
It shows these will -
'68-'72 Buick Special conv
'69 Buick Special 2 dr exc GS400 2dr ht
'71-'72 Buick Special 2 dr sdn & ht - exc 455"
'68-'70 Chevelle 2 dr exc El camino
'71-'72 Chevelle 2 dr ht & conv
'68-'70 Olds F-85 conv
'69 Olds F-85 2 dr
'71-'72 Olds F-85 2 dr
'68 Tempest conv
'69 Tempest 2 dr
'70-71 Tempest 2dr sdn & ht exc 455
'71 Tempest conv exc 455
'72 Tempest 2 dr exc 455
Old 11-03-2007, 03:31 AM
THANKS GUYS...
Old 11-03-2007, 03:44 AM
3macs1 3macs1 is offline
Don't have a book to check any more but I seem to remember a 4 inch difference in length and that a 4door chevelle and Monte may be the same but not two door.That is only off the top of my old head which is not like is used to be.
Old 11-03-2007, 06:53 AM
wheelhop wheelhop is offline
Any frame from a 68 to 72 A body will work. Chevelle, LeMans, Olds, etc.
I've got a spare frame if he needs one. Send me a pm
Old 11-03-2007, 06:22 PM
Unless your aiming for show points, keep your eyes peeled for the stronger 442/rag boxed frames..
And isn't it the extended length in the frame horns what makes the Gran Prix/Monte' ones wrong...remember those deep rad shrouds?.
Old 11-04-2007, 01:29 AM
Rainer Rainer is offline
Pete - its that as well as a stretched section from the firewall to the engine crossmember. Montes have a spacer between the firewall and wheelhouse, and the motor mount brackets are set back further on the crossmember compared to a Chevelle.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
