Old 11-11-2007, 08:00 AM
1969grb 1969grb is offline
Default 1969 Nova Radiator
Looking for 1969 Nova Harrison radiator with brackets, 396 with manual trans.Also need NOS door weatherstrips.
Old 11-12-2007, 03:36 AM
Default Re: 1969 Nova Radiator
Man they are easy requests! Marlin Spotts, Tommy Williams and Jason all on this site are probably your best bet. And I am sure a couple more may chime in. Good luck.
Old 11-12-2007, 03:55 AM
If it helps those searching,this is also the same radiator used on the 1968-69-70 L-34/L-78 TH400 equipped Nova,as well as the 1969 L-35/L-34/L-78~L-89 TH400 equipped Camaro.
Part #3017838 coded ZE
<u>Dimensions:</u>
16.97 Height
23.00 Wide
1.98 Deep
.16 Convolutions
390 Frontal area
4.6 Qts. capacity
Old 11-12-2007, 04:40 AM
Sorry,I've been working on a TH400 today.
That should read part #3017837 coded ZD.The standard radiator for those same M/T equipped vehicles,with same dimensions except a 4.8 qt. capacity..
