Old 12-30-2007, 08:04 AM
Andy Andy is offline
Default LS5 long block value?
This is the only forum I thought this question would fit, but if it needs to be moved some place else, then that is alright. My uncle has a complete LS5 longblock from a Chevelle. I am not sure what year LS5 it is but he is fairly certain it is from a 1970 model. It has been sitting on a stand for years and needs to be rebuilt. What would a motor like this be worth? The casting number on the back of the block is 3963512, and it has two bolt mains. It was an engine from a manual trans car I believe. It still had the flywheel on it. I will have to ask what the numbers are on the front pad, but I know that it had a C on the front pad, but I can not remember what the other letters/numbers where. The attached photo is the only picture I have of the complete motor.
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Old 12-30-2007, 08:14 AM
666 the legend 666 the legend is offline
Default Re: LS5 long block value?
...Could be a "427" or a " 454" according to the casting #'s..!!
Old 12-30-2007, 08:25 AM
rubbinisracing rubbinisracing is offline
The casting date will be very important
Howard
Growing old is a certainty, growing up isn't
Old 12-30-2007, 08:50 AM
427king 427king is offline
Yenko Paid Member
[/ QUOTE ] sounds like a 70 ls5 with a c code..also if its a 3 digit suffix its 70 or later and a 2 digit would be 1969..I's and L's[not c's] are normally found in 69 corvette and impalas.The c could also be CE
Old 12-30-2007, 09:06 AM
It is a C followed by two other letters. I'll get the info tomorrow and post it up on the board. Is there any other places I need to have him look on the block other than the front pad?
Andy
1972 Duster 340 727
Old 12-30-2007, 02:00 PM
Rixls6 Rixls6 is offline
If it's an original LS5 from a 70 Chevelle, then the code should be CRT. Chances are it's out of a car from Atlanta and would have the partial VIN stamped on the front pad also, like: 10Axxxxxx
If it was a Van Nuys built car, then the partial VIN would be down by the oil filter.
Old 12-30-2007, 06:53 PM
ANDY M's Avatar
ANDY M ANDY M is offline
According to Colvin, the "512" block was the only Chevy block used as both a '69 427 and '70 454, since GM had already made the decision to increase the stroke for the '70. This casting was also made with both 2 bolt and four bolt mains, and used in the big Chevys and 'Vettes in '69, and Chevelles added in '70.
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 12-30-2007, 11:44 PM
T0904CRN is what is stamped on the front pad. So it would be Tonowanda Engine Plant, September 4th and according to the big block engine suffix codes on http://www.nastyz28.com/gm-chevy-cod...-suffix-12.php, this is what it came out of.
CRN 1970 Chevelle 454 360hp manual trans LS-5
Andy
1972 Duster 340 727
Old 12-31-2007, 12:27 AM
I've seen two different hp levels with this engine as well, 360 hp and 390 hp, which is correct?
Andy
1972 Duster 340 727
Old 12-31-2007, 02:02 AM
Are you sure it's CRN?,I think that's out of a 1970 Monte Carlo with an LS-5/360HP M/T originally.
390HP was for the Corvette & Passenger series & Police/Taxi vehicles.
Are you sure it's not CRT?
