Old 01-05-2008, 06:49 AM
jasonL78 jasonL78 is offline
Default How do you guy's Install front spring!
Ok I am putting the front suspension back together on the 67 chevelle I am restoring. Everything is painted. How do you guy's install the front springs without scratching the paint! What is the secret!. I have one side in and I plan on doing the other side this weekend. I borrowed a nice snap on spring compressor becausee I broke my spring compressor the last time I took one out. Man what a feeling compressing that spring with an impact. I just don't feel safe! I spent most of the night with my eye's closed just waiting for the explosion!
Jason
Old 01-05-2008, 07:37 AM
John Brown's Avatar
Default Re: How do you guy's Install front spring!
All thread through the shock hole. Pipe sleeve on the top, 2x4 on the bottom. It's just too easy.
John Brown
Old 01-05-2008, 07:53 AM
RamAirDave RamAirDave is offline
I use a spring compressor. Tape up the arms to not scratch the spring. Also put a few layers of tape around the spring pocket in the LCA. If you need to give the spring a pry into the LCA, wrap up the pry bar as well.
It's not one of my favorite tasks, but Ive never had any problems and I install them without a scratch.
TheMuscleCarGuys.com
Old 01-06-2008, 06:32 PM
GeorgeLyons GeorgeLyons is offline
DO NOT use an impact on a spring compressor !!!!! Smooth ratchet operation only. I only saw one pop out on a '67 Corvette 25 years ago using an impact wrench. I will never witness another, I assure you. I you think you may want to use an impact to make it easier, call the Suicide Prevention Hotline in your town first and try to talk it out.
Old 01-06-2008, 11:07 PM
I agree, don't use an impact wrench. I just did this a few weeks ago on my 69 ElCamino. I used a 2 foot long breaker bar on the spring compressor, and used long smooth strokes. It is a little scary, but it has to be done. The spring has to be compressed to 13 inches long in order to install it in a 69. I would imagine 67 is the same. If it's compressed to 13 inches, you can stick it up into the frame and raise the lower control arm, and get the nut on the lower ball joint, without scratching anything.
69 El Camino
69 Nova
C7 Vette
Old 01-07-2008, 01:47 AM
njsteve njsteve is offline
An old safety trick they used to teach us in auto-tech school was to get a section of small chain and feed it through the coil spring and then make a loop and use a padlock and lock the end around the frame somewhere. This way if it ever lets go, there is a safety chain holding it from ricochetting across the room, or into your chest. Kind of like the same theory on why there is that little section of safety wire that is attached to any hanging lamp in your house. It keeps it from crashing down on your head if the mounting bolts goes south.
Old 01-07-2008, 03:46 AM
x  Baldwin  Motion's Avatar
DO NOT use an impact on a spring compressor !!!!! .... If you think you may want to use an impact to make it easier, call the Suicide Prevention Hotline in your town first and try to talk it out.
Old 01-07-2008, 03:50 AM
Thank's for the reply's and heads up. I did the otherside in 20 minutes and didn't even scratch the paint. You know when you are having trouble doing something it is alway's best to just walk away and come back and try later. This is what I should have done when I started having problems, I guess I learned my lesson.
Jason
Old 01-07-2008, 06:33 AM
P.J. P.J. is offline
another way to do it is
Take the sprigs to a local leaf spring shop. Mine was called ( Hard Dick Springs),Honest! where they will compress the springs to the max., then Strap them in place with steel straps in three places. Then place them in the location, hook up the arm back in position then take wire
cutters and cut the steel staps one at a time and bingo they are in. Take the steel straps out in pieces.When you cut them off the spring snaps into place.
no fuss no muss.
PJ
Old 01-07-2008, 07:23 AM
Went to school with a guy named Dick Springs,honest!
