Old 01-21-2008, 10:50 PM
x55gasser x55gasser is offline
Default 454 block
A friend got a 454 block and we are lost on the numbers on the front pad it has t0625crr and on the back of the block it has 3999289 and it is 4 bolt mains any info would be great.
Old 01-21-2008, 11:13 PM
LS6 RAT LS6 RAT is offline
Default Re: 454 block
That is coded as a 1970 Chevelle 454/450hp with TH400 transmission. The casting number puts it as a 1972 or later dated block.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 01-22-2008, 12:01 AM
yes thats were we get lost the date code on back of block is E-2-0 ment to put that in the first post?
Old 01-22-2008, 01:04 AM
I'm not aware of any casting dates after the '69 model year using only a single digit to represent the year of manufacture. I believe that stopped with the 1969 castings. Every 1970 and later cylinder case for 454 usage has as an example A 27 70 or B 17 71.
