Old 01-29-2008, 04:25 AM
lbnaz lbnaz is offline
Yenko Premier Member
Default L88 Cam replacement ???
Hello, looking to relpace a GM cam with either a NOS L88 or ZL-1 cam or a after market. Does anyone know which after market cam best meets the specs of the GM one. I have a crate L88 that was just fired and the cam went flat. Used the Rotella oil and all precautions but it still went flat on one lobe. Thanks, Larry.
Old 01-29-2008, 04:43 AM
COPO COPO is offline
Default Re: L88 Cam replacement ???
Crane has their blue print cam series that are supposed to be a match for original Chev. cams.
Old 01-29-2008, 05:14 AM
VintageMusclecar's Avatar
I would strongly recommend using a set of lifters with an EDM bleed hole for added insurance next time around.
Also be sure to remove the inner valve springs and break the cam in on the outers only.
Eric
Old 01-29-2008, 05:52 AM
Born30YrsLate Born30YrsLate is offline
What's the best place to get them bad-boys from?...
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 01-29-2008, 05:57 AM
Most of the larger mail-order places carry them. I can get them for you as well.
Eric
Old 01-29-2008, 06:50 AM
Hello, I used a set of the lifters you mentioned. There about 170 bucks. I am looking at the Crane cam thats mentioned. Larry.
Old 01-29-2008, 07:25 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is online now
I have one in my 70 Z28 and no problems whatsoever!
1970Camaro Z28
Old 01-29-2008, 10:05 AM
Mr. Chevy's Avatar
I prefer Comp. Cams thats what I have in my Nova (L78 spec cam) and it works great!! A lot of guys here on the site however swear by the Crane blueprint cams...
Rich
Old 01-29-2008, 03:23 PM
TDW TDW is offline
For American made EDM lifters, Howards Cams has them. Nice parts.
http://www.howardscams.com/
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 01-29-2008, 04:46 PM
YENKO DEUCE REGISTRY's Avatar
Ditto, have the Crane LT1 cam in my Deuce, no problems. A mutual friend took a 6k mile LT1 cam, an NOS LT1 cam, and the Crane blueprint LT1 cam and put them all on a Cam Doctor. No differences!
Marlin
