Old 02-01-2008, 08:02 PM
dlv4540 dlv4540 is offline
Default 1969 427 replacement block & 1970 LS6 blocks
1969 427 CE block casting number 3963512 dated H-20-9 all done with new cam bearings and freeze plugs. Block will come with #7115 crank, dimple 7/16 rods and closed chamber TRW pistons and rings, new cam and lifters (solid) and double roller timing chain $4,000. 1970 454 blocks first one is dated J-10-9 and is a fresh 30 over $2500 and the second block is dated L-2-9 and is 60 over with one sleeve and pressure tested $2,000. I also have one set of 7/16 dimpe rods for $250. 1970 blocks are also 3963512 casting numbers and all the blocks listed are 4 bolt blocks. 330-770-2517
Dennis Vugrinovich
