Old 02-05-2008, 05:10 AM
Unreal Unreal is offline
Default Motor Mounts
I was told that 39909118 is the correct part number for a 69 big block Camaro motor mount. Is this correct, and if so, is it the interlocking one?
I have an interlocking mount with the following molded into the rubber on the side. It has green paint across the DK GREEN line.
3968700 BLACK
3962745 DK GREEN
3962740 Gold
3974735 GOLD/NUT
I only have one, so I'm trying to determine what I should be looking for.
Old 02-05-2008, 08:40 PM
Default Re: Motor Mounts
That's correct,as well as Camaro w/302-350cid and 69 Novas w/SB & BB.
Those are actually 3990918 & 3962748.
Are you looking for another?
Old 02-06-2008, 02:31 AM
Yes Rick, I am looking for another.
I had a pair of NOS non-interlocking ones on my car until I pulled the motor to deal with a wiped cam. I was planning to install a lift stop kit, in case they let loose. I have 1 NOS interlocking one, and if I can find another before I drop the motor back in, I'd prefer to use them. I also have a pair of auto parts store interlocking ones that look like they will work, if I can't find a matching NOS one.
