Old 03-19-2008, 09:35 AM
Ozark Ozark is offline
Default Hennessey Challenger
SRT700 Turbo - 426 CID Engine Upgrade
Power:
# 725 hp @ 5,200 rpm
# 750 lb-ft @ 4,000 rpm
Estimated Performance:
# 0 - 60 mph: 3.5 sec. *
# 1/4 mile: 11.3 sec. @ 126 mph *
# Top Speed: 190 mph
* with Drag Radial Tire Upgrade
Includes:
# 426 Cubic Inch Displacement Stroker Motor
# 9.0:1 Compression Forged Aluminum Pistons
# Forged Steel Connecting Rods
# 426 Stroker Crankshaft
# Balanced Rotating Assembly
# High Flow Cylinder Heads
# Polished Intake Manifold
# Single 67 mm Turbocharger
# Stainless Steel Turbo Y-Pipe
# Single 44 mm Wastegate
# Stainless Steel Dual 3 in. Exhaust System with Polished Stainless Steel Exhaust Tips
# Front Mounted Air-to-Air Intercooler
# 3.5 in. Polished Inlet Tube with Blow-Off Valve
# Upgraded Fuel Injectors
# Upgraded Engine Management System
# 180 degree thermostat upgrade
# All necessary gaskets and fluids
# Professional Installation
# Chassis Dyno Testing
# Road Testing (up to 100 miles)
# One year limited warranty
Old 03-19-2008, 03:16 PM
flyingn's Avatar
flyingn flyingn is offline
Default Re: Hennessey Challenger
niceeeeeee
Frank Szymkowski
Old 03-19-2008, 07:53 PM
1970Bluel78 1970Bluel78 is offline
Whats that puppy gonna cost?
1970bluel78
Old 03-19-2008, 09:59 PM
doenst 11.3 seem a little slow for a 725hp monster?
Founder of Lost Muscle Cars
Discovered; 1968 Dick Harrell L88 Super Chevelle, 1969 Ford Boss Bronco, 1969 KK1201 Boss 429 Prototype, 1964 Savoy 426 Max Wedge (steel nose), 1969 Nova L78 Yenko Sold
Old 03-19-2008, 10:10 PM
427TJ's Avatar
427TJ 427TJ is offline
"Price: Call"
Better be sitting down when you do.
Still, that would be a hellofa car with that conversion. Too bad it's probably $$$ ($$) once it's all totaled up.
Old 03-19-2008, 10:11 PM
427TJ's Avatar
Probably can't get all 725 to the ground!
Old 03-19-2008, 10:22 PM
Pushing 2+ tons! That's alot of heft to get movin'.
Betcha' it's a real beast .....
Old 03-20-2008, 05:40 AM
JK98SS JK98SS is offline
I think they are right around 4,100 pounds. My car put down 374 RWHP naturally aspirated and has gone 11.9 and weighs almost 3,500#
Old 03-20-2008, 09:34 PM
agtw31 agtw31 is offline
is this the same Hennessey guy that's being sued by a bunch of Viper folks?
Old 03-21-2008, 03:26 AM
flyingn's Avatar
one in the same..
Frank Szymkowski
