Old 03-31-2008, 04:38 AM
302moz 302moz is offline
Default 1968 and older original non locking motor mounts
Wanted 1968 and older good used or nos non locking rubber motor mounts.I need them for a 68z ,but alot of other small block and some big blocks used them. 307 and 327 also used them on camaros in 69. call 9063371025 or 9063373928 or email thanks John
Attachments - The Supercar Registry 331065-tn_motormount3.jpg 331063-tn_motormount2.jpg 331062-tn_motormount.jpg
Old 03-31-2008, 05:22 PM
68z302 68z302 is offline
Default Re: 1968 and older original non locking motor moun
John,
you're more likely to find one from a 64 to 68 big block car (pass & corvette)if you're looking for a used one. the drivers side are usually torn up.
I looked for a long time to find a match for the one I had & finally got one.
http://cgi.ebay.com/ebaymotors/ws/eB...m=140203140089
It's basically a big block of rubber.
Good luck
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 03-31-2008, 06:17 PM
KevinW KevinW is offline
I think I may have some of those, the pic looks familer. I will look tonight.
69 327 convertible (driver)
Old 04-01-2008, 01:01 AM
John,
I just picked this pair up. However, one is slightly different than the other but they came off the same car.
Old 04-01-2008, 03:29 AM
The z/28 mount in '68 is not the 'standard' non interlock.
It's much beefier.
Big Block pass cars & corvette used these from '61.
Part # molded in is 3886466 if someone wants to search it against a parts book.
I'll try & post some pics.
Rob
Old 04-01-2008, 03:41 AM
I have one, is not exactly like the ebay auction one. Where is the part number located?
Old 04-01-2008, 05:44 AM
If you reference the auction pics,
3886466 is molded into the top of the rectangular
area on the RH side.
That would be the frame side.
Rob
Old 04-01-2008, 07:18 PM
jasonL78 jasonL78 is offline
Look at this link on team chevelle I replied too.
http://www.chevelles.com/forums/showthread.php?t=217258
For my 68 L78 nova I had a hard time finding the correct motor mounts for my original frame mounts. A friend at gm came up with this part number GM# 6258154 and they fit perfect(And still avaliable). I think they are the same for the small blocks?
Jason
Old 04-01-2008, 10:08 PM
The motor mount I have does not have that block on the top, and no part numbers I could see. I will post a pic tonight.
Old 04-02-2008, 05:01 AM
Here is mine, what is it?
