Old 06-10-2008, 12:03 AM
Default Air conditioning question
I just recharged the A/C on my 69 Camaro. There was still pressure in the system when I charged it but the A/C was not getting cold. I thought the system had just got low since the last time it was charged was 1986. After charging the system the air is still coming out hot. I thought the heater valve may be stuck open so I zip tied a kink in the heater hose right before the valve. The air is still not cold. The compressor kicks on when the switch is turned on and the metal line coming out of the A/C breifcase is ice cold with frost on it. Any ideas?
Thanks,
Jason
Old 06-10-2008, 12:46 AM
Default Re: Air conditioning question
The guys on team chevelle/camaro have a really good handle on AC problems Jason...post your question there and it will be answered PDQ!
Old 06-11-2008, 03:41 AM
Thanks. I will make a post over at Team Camaro.
Jason
Old 06-11-2008, 03:50 AM
An idea of how cold its getting:
But its still not cool inside.
Jason
Old 06-11-2008, 04:21 AM
wagonman wagonman is offline
Thanks,
Jason
do you have a/c gauges?
you actually need to connect them so we can have some answers of how your system is running right now....
before you waste valuable R12........
it may still be low......
or...........
how much preasure was in the system before you recharged it?
if it was only a few pounds then the system may have been zero at one time.now only showing presure based on a warmer ambient temperature.if it ever became low enough(equal to or below atmospheric pressure) in your case sea level 14.7 psi you will have moist atmosphere enter your system.contaminating the syatem with moisture.Santa Cruz has 80 percent or more relative humidity many days of the year!
it may be a good idea to evacuate your system and start over..
Old 06-11-2008, 04:31 AM
There was pressure in the system before I started but I do not have gauges to see how much.
Jason
Old 06-11-2008, 04:47 AM
ok,
but how much preasure?
understand that if it only had a few pounds on a warm day,it may be possible to have been zero on a cold one.
therefore contaminating the system with air,moisture etc....
1969 rs/ss 396 350hp/4spd conv
1968 Z/28 crossram- j/l8 conv
1963 nova ss 350/4spd conv
Old 06-11-2008, 04:59 AM
I understand. I can not say how much pressure. I just know when I pushed on the valve it made a loud hiss. I think I will take it to the A/C shop tomorrow to have it checked out. I just thought there may have been a simple issue that I missed.
Thanks for the help,
Jason
Old 06-11-2008, 05:27 AM
ok,
good luck and post on here what you find.
others that may be reading can possibly learn from your situation.
Old 06-11-2008, 04:35 PM
Woj's Avatar
Woj Woj is offline
Looks like your POA valve is not opening. Time to get the mallet out and give it a few taps.
You should get a set of guages and find out what pressures are on both sides of the system (hi press and low press).
Good luck.
Phil Woj.
