Old 06-26-2008, 01:56 PM
68Biscayne427 68Biscayne427 is offline
Default Muncie Tranny Question
OK. I got my new rear axle housing installed with the new gears and carrier unit. Everything runs well. I did change the gears from 3.43 to 4.11s and now the speedo is correct at all speeds. Where as before it was off anywhere from 5 - 15mph. Question: wouldn't it make sense that if a Muncie 4-speed had a 4.11 speedo gear installed, (for the speedometer) that it would be a close-ratio 4-speed? I have yet to figure out if the tranny is a M20, M21 or M22. It does have a wine when I drive it but I have never heard a "true" M22 to compare it to. It almost sounds like a small blower when I am driving it...
Thanks - Rob
Rob M.
'68 L-72 Biscayne, M22 4-speed
Old 06-26-2008, 02:42 PM
Default Re: Muncie Tranny Question
Does the trans have any letter codes on it? A,B, or C after the stamped number on the case?
Old 06-26-2008, 03:18 PM
No it doesn't. My car is a '68 and I believe they started putting letter designations on Muncie's in Oct. '68 for the '69 model year.
Rob M.
Old 06-26-2008, 04:18 PM
Born30YrsLate Born30YrsLate is offline
how many grooves on the input shaft? In general...
2 - m20
1 - m21
0 - m22
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 06-26-2008, 04:31 PM
Can I see the input shaft without taking the transmission out of the car? Or the clutch?
Rob M.
Old 06-26-2008, 07:14 PM
Check and see if the trans has 2 pipe plugs in the case... one for fill and one lower to drain the case... if so it is a M22 case... no guarantee the straight cut gears are still in the trans, but the chances are better than not!
Old 06-27-2008, 02:58 AM
crash crash is offline
In 1970 model year and later all Muncie main cases got fill plugs and drain plugs, reguardless what the ratio... Crash
Old 07-11-2008, 06:50 PM
I know this is an old posting but I thought I would update you guys on what I found.
About 2 weeks ago the drive-shaft let go when I was going about 75mph - What a mess. It broke all four ears of the transmission including the bottom one where it not only broke the ear but cracked the whole bottom part of the case. I pulled the tranny and sure enough it had two lines on the input shaft - m20. The whine was probably from a bearing that must be bad. At any rate, the car is on jack stands again.
I plan on installing an Auto Gear case along with the heavy duty M22 gear set so I will eliminate another weak link of my drive-line....
The only thing that is left is the motor, and the guy who built that said that was bullet proof. Well, if he built the rear end or transmission like the motor, I'm in deep trouble!!
Rob M.
Old 07-12-2008, 05:03 AM
I don't know about '68s but our COPO Chevelle had the 4.10 gears and and M20 Muncie.
