Priced at $72,000 - Pretty rare 62 BelAir Bubbletop 409/409 Dual quad car, 4:11 rear, believed to still have the original drivetrain, original shifter long gone, owner still has the orig exhaust manifolds, ceramic coated headers are installed in the car currently.
Car belongs to a close friend in Temecula, CA - great guy. Here is his description: SOUTHERN CALIFORNIA CAR (Located there currently) Exceptionally well restored and detailed example of one of the most highly desirable performance cars produced during an era in which the “big block” muscle car reigned supreme. Below is a comprehensive list of the many new, rebuilt and reconditioned components of this beautiful, legendary automobile. All work was launched/completed with reliability, performance and re-marketability in mind; nothing has been overlooked. It starts with exceptional ease, sounds absolutely awesome at idle and operates well within a reasonable temperature range during 100+ degree Southern California summer days. The advanced stage of tune and upgraded power disk braking system ensure a combination of spirited acceleration and appropriately predictable stopping power. This multi-time "Award of Excellence" winner, along with its accompanying paperwork, would disappoint no suitably discriminating buyer. Please consider the following restoration details and snapshots. ENGINE, COOLING, DRIVE LINE, REAR END AND EXHAUST Rebuilt - Engine (approximately 50 miles) .30-over 409 CI, 409 HP (11.0:1 compression ratio) New - Doug Thorley “Tri-Y” headers New - Starter New - Pertronix electronic ignition New - Radiator hoses New - Draft tube and mounting hardware New - Horns New - Wheel well splash guards New - Oil pan New - Oil pressure sending unit New - Water temperature sending unit New - Oil filler neck, breather and dip stick New - Fuel pump New - Carburetor linkage New - Valve cover screws and rubber seals/washers New - Air cleaner gaskets New - Flywheel and entire clutch mechanism New - Universal joints New - Axle bearings/seals, pinion bearing/seal and filler plug New - 4-core radiator, petcocks, hoses and coolant recovery bottle New - Hood insulation New - Hood bumpers, adjusters and hood-to-cowl seal New - Voltage regulator New - Horn relay New - Battery, cables and acid splash guard New - Placards Reconditioned - Carter AFB carburetors, water pump, generator and steering box Reconditioned - Transmission bearings, seals, breather, speedometer cable seat and reverse switch Reconditioned - Valve covers (powder coated) INTERIOR New - Carpet, floor mats, package tray, arm rests and kick panels Recent - Seat covers, door panels and headliner New - Heater delete New - Radio delete New - Clock delete New - Firewall insulation/cover New - Rear view mirror New - Turn signal stalk New - Sill plates New - Rear seat ashtrays New - Door lock knobs and ferrules New - Sun visor swivels New - Ceiling light New - Ceiling light actuators New - Brake light actuator New - Garment hooks New - Package tray New - Interior-to-trunk divider New - Accelerator pedal New - Seat adjustment knob New - Arm rests New - Door handles New - Window cranks (including vent windows) New - Hurst shifter, boot and ball New - Pedal covers New - Dash escutcheons New - Headlight switch New - Cigarette lighter New - Internal column mounted turn signal and horn assemblies New - Speedometer cable New - Pioneer CD player (removable face) and Kenwood 3-way speakers - all discreetly installed above passenger foot well with remote control New - Interior screws and light bulb kits Reconditioned and modernized - Sun tachometer and remote sending unit Reconditioned - Front seat ash tray, fresh air vents, seat belts, front seat pedestals, steering wheel, glove compartment, sun visors, parking brake assembly and door/window trim pieces Reconditioned - Chrome lower windshield trim, mid-dash trim, glove compartment door assembly, radio delete plate, ash tray door and heater delete plate EXTERIOR Recent - 2-stage paint New - Goodyear Eagle RS-A premium tires New - Wheel bearings and grease cups New - Driver’s side rear-view mirror New - Door/window seals and cat whiskers New - Roof rail weatherstrip New - Rear window U-seals New - Door weatherstrip New - Front door drip channels New - Tail light lenses and body gaskets New - Tail light-to-body seals New - Upper grill teeth New - Rear cove trim New - Hood lip trim New - Hood emblem Reconditioned - Powder coated wheels Reconditioned - Chrome trim (including dog dish hub caps) Reconditioned - Stainless and aluminum trim New - California Car Cover TRUNK New - Weatherseal New - Splatter paint New - Trunk mat New - Interior-to-trunk divider Reconditioned - Jack and tire tools New - Spare tire cover UNDERCAR New - Speedometer cable New - Fuel tank, sending unit, clamps and miscellaneous hardware New - Filler-neck-to-fuel-tank hose New - Tank straps MISCELLANEOUS • New - Owners Manual, 1961/1962 Shop Manual, Assembly Manual and New Car Retail Accessory Price List • Valuable parts, paint and etc. ![]() ![]() ![]() ![]() Dave Castine EMAIL: [email protected] PHONE: 617.513.7407 |
