Old 07-15-2008, 10:40 AM
sbted95 sbted95 is offline
Default 1969 Camaro RS/SS BB vs SB Question
Guys,
I have been in the process of restoring my car for the last 2+ years. While I have been studying 1st generation Camaros for quite some time, this car is confusing me! When I bought the car, it had a cheap coat of paint on it but was VERY rust free and in overall nice shape. It is the rallye green color and has all RS/SS equipment (12 bolt, PDB, hide away headlights, the correct vacuum lines for the headlights, the longer hood springs, proportioning valve, SS hood, etc. ). As we have been tearing into the car, I have ran across a few confusing things regarding if it was a BB or SB car. When I bought it, it had a SB heater core cover and a SB crossmember. So, I bought a zz383 thinking it was a SB car and just threw it in. Well, the front end is sitting darn high and as I checked out the front springs, I realized it has BB springs still with what looks to be an original tag on the bottom of the driver's side. For what-ever it is worth, the panel around the tail lights was black when I bought it. Now, I realize someone could have added paint, springs, heater core cover, etc... I am to the point where I want to pull the ZZ383 and buy a date coded 396. I do not have the build sheet or any original documentation. I do not plan on restoring this to a concourse quality. I want to do the right thing in the restoration. However, I am sort of stumped. The numbers for the car include:
VIN# 124379L516105
Tag Info: ( _ is a space)
Top Line: ST_69_12437_VN232672_BDY
2nd Line: TR_711_79_79 PNT
3rd Line: 1B_F586
Front spring number (a number or two could be off: 3955770EK
Note: The rear from the center to the axle has 5 leaf springs
Other car tidbits FYI when I bought it:
The rear louvers were not there
It has the standard black interior
As we have torn into the car, the front end seems as if it has never been off
Help!
Ps- Hopefully I do not sound too stupid! I also posted this on camaros.net
Old 07-15-2008, 03:00 PM
Default Re: 1969 Camaro RS/SS BB vs SB Question
Welcome
3955710EK was possible in Camaro 12437 model applications w/SB L-48 or L-65,not BB.
Old 07-15-2008, 03:58 PM
JRSully JRSully is offline
It may have had a heavier spring rate (reason it is sitting so high) because of possible options added on the engine and the RS equipment.?
71 Porsche 911 Targa
Old 07-15-2008, 05:28 PM
Thanks guys! As much as I would love to have a BB in my car, I just want to do it right! Also, since I have a SB in there now, it would be much easier to keep it as is. Now I need to find a date coded 1969 350! Thanks again.
Old 07-16-2008, 12:47 AM
BARNFOUND YENKO BARNFOUND YENKO is offline
Never underestimate a nice high horsepower smallblock as they can/will fool you.
SURVIVOR 1970 PLYMOUTH SUPERBIRD
ORIGINAL 1969 CAMARO Z/28
1968 CAMARO RS/SS L89 CONVERTIBLE-1 OF 1
Old 07-16-2008, 07:47 AM
True....actually, the SB I am putting in is "rated" as having 425 HP. It should run pretty well! While one cannot beat the torque of a BB, I am pumped for a solid running SB!
Old 07-17-2008, 10:12 AM
rspanther rspanther is offline
I might have a date coded 350 . What month do you need? I am about 30 minutes from you.
David
Old 07-17-2008, 11:17 AM
January...2nd week of the month. If you have one, give me a call at 503-703-4065. Thanks!!
Old 07-20-2008, 07:16 PM
rspanther,
Even if you do not have the exact date coded block, how close do you have? FYI...if you tried to call me yesterday (or try today), my phone is not working due to getting a little shower! You could call 503-703-9512 for a backup. Thanks. I truly am in no rush if you have better resources to get a good block.
