use the powder mixed with water to make a slurry then make sure to keep the wheel wet with water, it will keep the heat down.... it will be a bit messy slinging the compound around, keep from too high of rpm's on the polishing head, rule of thumb is if you can feel the scratches with your finger nail they won't polish out with good results, it will be a pretty slow process.
