Old 07-30-2017, 04:21 AM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default 1974 Trans Am 455 SD, Project Car
1974 Trans am 455 SD, GM of Canada Documented Numbers match car. Red with Black. Auto, A/C. Tilt, PW and more.
This car requires a restoration and engine and transmission are out of the car. All original Drive train including Engine, Transmission and Differential. The numbers matching short block has been rebuilt and is wrapped in plastic. Heads were rebuilt at one time.
Original Carb, Intake, Heads, Alternator, EGR valve, Valve covers and more.
Distributor is not original, no camshaft, has headers but have a new set of reproduction exhaust manifolds from Ram Air Restorations, These were purchased in 2006. The dash pad has a crack on the passenger side, but the package on the roof in some pictures is a very nice original black dashpad that comes with the car.
I am in no way a Pontiac expert, this is the only Pontiac I have ever owned. Reply with questions and I will answer them to the best of my ability.
Car is located in Calgary Alberta Canada.
$28,500 US.
Attachments - The Supercar Registry wqeweeq.jpg wqeqeqwe.jpg SDSDDD.jpg sdfdfsdfd.jpg
Old 07-30-2017, 11:44 AM
NICE!
Old 07-30-2017, 02:08 PM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
Can we get a picture of the VIN on the block, and the underside and lower panel pictures please.
Old 07-30-2017, 06:17 PM
I'm guessing the car has had one repaint?
If so---
Is there any rust repair in the quarters?
Are the frame rails solid?
Old 07-30-2017, 09:51 PM
RST's Avatar
RST RST is offline
I think that is a fair price, distributor is a bummer.
1968 1/2 Cougar 428 R Code, Cobra Jet, 4 SPD, Red Interior in restoration at MASCAR to be unveiled by Kevin Marti at the MCACN 2020
1970 Top Secret Very Special Muscle Car in restoration by MASCAR to be unveiled at MCACN 2020
Old 07-31-2017, 01:07 AM
Default Sd vin , engine vin, trans vin
Here are some pictures of the vehicle Vin on Block and Trans
Old 07-31-2017, 03:05 AM
Default 1974 Super Duty Vin Pictures On Block & Trans
The Good, The Bad and the Ugly, Here they are, assorted pictures of the Trans Am SD. The car had 1/2 quarter panels installed many years ago, now bubbling around where the filler was towards the rear. 1 repaint.
Old 07-31-2017, 04:24 AM
RST's Avatar
RST RST is offline
oK ............ Now that i see some scary rust ..... price may be agressive.
Old 07-31-2017, 04:28 AM
KenMaisano's Avatar
All numbers one of 700 Auto cars. The price is very fair.
Old 07-31-2017, 07:11 AM
Default body pictures 455 SD
If that is a lot of nasty rust to you, you should see the cars from eastern Canada. Here are some more pictures.
