Old 11-03-2020, 09:49 PM
chris slawski chris slawski is offline
Default Air cleaner base id
Hey folks
Big dummy here thought the GM 69 open element air cleaner bases were the same. The one on the left is a repo the lined up correctly on my 69 L78. The one on the right the vent tube points at incorrect angle for my application...but what is it for?
Thanks in advance
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
Old 11-03-2020, 10:07 PM
Default Air Cleaner base id
That base is for the '68 & '69 427/390 hp Corvette, the '70 Corvette 454/390 hp, the '71 Corvette 454/365 hp & 454/425 hp air cleaner. It was designed for a flat runner intake manifold.
The Following User Says Thank You to Flying Undertaker For This Useful Post:
chris slawski (11-03-2020)
Old 11-03-2020, 10:59 PM
DWR DWR is offline
Possibly 70 Chevelle without cowl induction. Uses bent hose to connect base to valve cover.
Old 11-03-2020, 11:05 PM
x2
minus that the 71 Corvette LS5 uses a dual snorkle base.
If not mistaken wouldn't the chevelle have a dual snout like Dave Beem's 4300 mile LS6?
Old 11-03-2020, 11:14 PM
Three possible Air cleaners were used on the 1970 Chevelle LS-6.
SS~Open Element
DG ~Cowl Ind.
CO~Dual Snorkel
Take better pics of the Air cleaner on the right & post here,include close up angle of Vent tube.
Old 11-03-2020, 11:19 PM
SS~Open Element
DG ~Cowl Ind.
CO~Dual Snorkel
I thought that Chevy stopped using the Open Element Air Cleaner on all 1970 model cars EXCEPT the Corvette in an effort to cut back on noise levels which was a mandate by the EPA.
Old 11-04-2020, 12:15 PM
1970 Camaro L34 had an open element AC. Nova also I believe.
Owned since 1978 - First Car
Old 11-04-2020, 09:01 PM
Default LS6 air cleaner
That dual snorkel air cleaner is awesome looking on the White 14K mile all original LS6 car, but I could be a little bias.
Dave.
Old 11-03-2020, 11:51 PM
Nope.
Old 11-04-2020, 02:57 AM
Nope.
If that's the case then how would you tell which air cleaner came on your LS6 without Cowl Induction?
