Old 05-19-2021, 03:26 PM
Originally Posted by Zman1969 View Post
so your post wasn't related to my initial post was it?
Yes...it was actually. Many of the cams that you were provided including the so-called "several" I suggested were very suitable choices for an LT1 build. The roller cam I suggested with its 236/240 duration is an excellent hydraulic roller camshaft for an LT1 and makes enough vacuum to handle power brakes as well as support the RS headlamp operations. You did also say in your original post that you had no issues with a roller cam...did you not?
I have no issues going back flat tappet or even a street roller
Well? That was a really good street roller. If it's a little too lumpy for you, then understand that the entire line of hydraulic rollers is easily bumped down a step or two to what becomes a very mild-mannered street cam, and is totally forgiving on the valve train. Something the guys at Crower could have easily helped you out with. Seriously...they work with everyday people to help select camshafts all the time.
All snide aside...good luck with your engine build.
