Old 06-15-2021, 02:39 AM
Originally Posted by thehornworks View Post
I just thought of something. Are you using the resistor wire in the harness, this lowers the voltage to the points after you start the engine ?
Good thought. The resistor wire actually reducing the voltage when the car is running. Another wire comes to to the coil to provide more voltage when cranking. If the resistor wire was replaced with a standard wire at some point than that could definitely be prematurely wearing points and throwing the dwell off.
Jason
Rumbleguts396 (06-15-2021)
  #12
Old 06-15-2021, 10:35 AM
Rumbleguts396 Rumbleguts396 is offline
Interesting Jason. I'm going to have to look at that !!!! Thanks ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 06-15-2021, 10:39 AM
racer67x racer67x is offline
I ran a 396 with points in my Chevelle years ago...added an Accel coil and ran a Chrysler style ballast resistor in the wire.
that eliminated my problems and I always carried a spare in the glovebox.
you could try one to see if it helps..
The Following User Says Thank You to racer67x For This Useful Post:
  #14
Old 06-15-2021, 12:46 PM
You state that the points always look new when the failure happens. Using a full 12 volt wire would badly pit the points. You can verify the original low voltage wire by the woven fabric on it at the coil plus terminal.
It could, also, be the condenser failing and shorting out. Are you installing the separate condenser and points, or the uni-points with attached condenser. I don't know if the the uni-points are even made anymore, as they were notoriously famous for premature failure.
Also, make certain the distributor point plate has a good ground to the distributor body and the body has a good ground to the engine thru the clamp and bolt. A bad ground could overheat the condenser and cause it to fail.
Old 06-15-2021, 02:15 PM
x33rs x33rs is offline
What others are mentioning is easy to test.
While the car is running just check voltage at the coil. Should see roughly 9 volts or so. If you see a full 12 or more that may be your issue.
Since you mentioned you've had this car running for the last 12 years without an issue and this just recently cropped up, My guess is the problem is elsewhere.
The Following 3 Users Say Thank You to x33rs For This Useful Post:
earntaz (06-15-2021), Rumbleguts396 (06-15-2021), Xplantdad (06-15-2021)
  #16
Old 06-15-2021, 07:13 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Pertronix and done... If you weren't Day 2 etc., I'd say leave it points. I've been running a set in my 69 for the past five years. Not so much as a hiccup from them. I use a factory distributor. You'd only notice if you took the cap off. Hardest part of the install is having to run a full 12v versus the factory resistor wire. Very easy...
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
The Following User Says Thank You to HawkX66 For This Useful Post:
  #17
Old 06-15-2021, 07:55 PM
BCreekDave BCreekDave is online now
Isn't the Pertronix a two-wire setup? Maybe they changed. The Breakerless SE http://www.breakerless.com/
was the only single wire points replacement I was aware of.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
  #18
Old 06-15-2021, 08:15 PM
I'm using separate condsenor. I have been changing them both when the issues start. ROB
