Old 06-27-2021, 03:21 PM
enio45 enio45 is offline
Default Oil Pan Difference - 69Z
Friend of mine called and asked if I knew what the difference would be in a 69Z oil pan - vs. a 1970? Seems his sept of 69Z has a 70 oil pan?
Any insight as to the differences - or would a late 69 have a 70 pan, similar to other late 69-70 transition parts?
Appreciate your insight on this....
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Attachments - The Supercar Registry 20210701_162137.jpg 20210701_162004.jpg 20210701_161716.jpg
Old 06-27-2021, 03:56 PM
X66 714's Avatar
X66 714 X66 714 is offline
Seems to me there was a big article on this site some years back. I'll see if I can find it unless somebody know exactly where it is....Joe
Old 06-27-2021, 05:55 PM
Eddie; I can't tell you if there was a difference between the 69 and 70 assembly line pans.
I do know some late 69's got the second design valve covers with drippers, starting in about August. It would make sense that IF the 1970 Z/28 oil pan was functionally the same, they COULD have started using it early.
I know for certain that the 69 assy line pan has multiple differences from the ones that were sold over the counter starting some time in the 70s.
Comparison is here: https://www.camaros.net/threads/nos-...l-pans.178450/
Old 06-27-2021, 09:32 PM
Lynn, That is my thought - but i guess we would need some examples of the late cars inspected and determined if either pan was used.
i did see your thread on the camaro net site - interesting and informative.....
looking for more info.....thank you...
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-27-2021, 09:49 PM
Guessing my first question is:
Are we certain that 69 and 70 Z/28 used different oil pans?
Would like to see pics of each to compare.
I do have a 1970 LT-1, but it is a Corvette, so the pan is MUCH different from the Camaro.
Old 06-30-2021, 01:18 PM
Perhaps Mike (RSZMJT) can chime in on this. He has had many of these pans off and probably knows more than enough about the differences between the 69 Z pans, 70 LT1 pans, and most of the corvette pans. I recall there are a couple of differences between them but will leave him to chime in and tell you about those if he sees this thread.
Old 06-30-2021, 04:00 PM
jl8z28 jl8z28 is offline
I have a 11A of 69 car i don't know if you can tell difference on the outside ill look at my may car and see
Old 06-30-2021, 04:02 PM
I have a 11A of 69 and a may ill check a see if there is a difference on the outside
Old 06-30-2021, 04:03 PM
that would be great - his car is a 9C - late 69 car.....
pics would help - to understand the assembly line correct version etc......
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-30-2021, 04:18 PM
Zman1969 Zman1969 is offline
I know the later L-82 pans are similar but had noticeable external differences in the strengthening "ribs" that are pressed in for strength also slight internal changes too
here's a good thread with info
http://www.camaros.org/forum/index.php?topic=15386.0
http://www.camaros.org/forum/index.p...76264#msg76264
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
NorCam (07-01-2021)
